Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: Feed,Spindle RPM , Depth of cut
    Feb 2011
    Exclamation Feed,Spindle RPM , Depth of cut
    Please forgive me if this is inappropriate thread here
    I have a small part to mill. I will use my CNC X2 LMS mill. The material I will use is 6061 3/8" thk aluminum. The part will be cut out out of 3.5" x 2.5" scrap.
    What feed , spindle speed and cut depth should I use for each pass? I will use 3/8" flute with two teeth.
    May 2004
    Get a copy of Machinery's Handbook and learn to use it.
    Assuming uncoated carbide, I would start with 450 SFM. So, now let's learn to do the math on that. SFM is Surface Feet per Minute. Your end mill is measured in inches. So, you have to do a conversion.
    RPM = (SFM X 12") / (d X PI)
    RPM = (450 X 12) / (0.375 X 3.1415)
    RPM = 5400 / 1.1781
    RPM = 4584
    Now for feed rate. I would start with 0.004" per tooth. More math:
    Feed = RPM X Feed per tooth X Number of teeth
    Feed = 4584 X 0.004 X 2
    Feed = 36.67 IPM
    For depth of cut, I usually start with what I call 50/40. 50% of diameter for Axle and 40% of diameter Radial Depth of Cut (DOC). So, 0.1875" for the axle DOC and 0.150" for radial DOC.
    Most of this information is in Machinery's Handbook. Examples of the math are in Machinery's Handbook.
    http://www.kirkcon.com/
    Feb 2011
    txcncman thank you for your reply. My machine can only go 2500 RPM. So if I want to run it on 2500 RPM I have to pick 250 SFM?
    Why you choose .004"? Is there a definition or some kind of table?
    May 2004
    Quote Originally Posted by Pysiek View Post
    If the RPM calculation gives you a number higher than the limits of your machine, you have to use the limit of your machine for RPM. So, the calculation gave 4584. You will use 2500. This changes the feed rate calculation:
    Feed = 2500 X 0.004 X 2
    Feed = 20 IPM
    I choose 0.004" because you are machining aluminum and not steel or stainless steel.
    Tables are in Machinery's Handbook along with descriptions and explanations of machining operations.
    Feb 2011
    One more question. Where did you get the 450 SFM from?
    And the tool is HSS
    Gold Member hoss2006's Avatar
    Apr 2006
    Physiek, here's a HSS Feed and Speed chart, go with no more than .002 chip load for the X2, carbide could run higher.
    http://www.endmill.com/pages/trainin...nd%20Mills.pdf
    Also here's a nice Speed and feed calc.
    Milling Calculators
    The best would be Bob's GWizard.
    GWizard: A CNC Machinist's Calculator for Feeds and Speeds
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    May 2004
    And the tool is HSS
    I got 450 out of my head. The actual low end of the scale is 500. Here is a chart from Machinery's Handbook for your use:
    Attached Thumbnails Attached Thumbnails Feed,Spindle RPM , Depth of cut-speedfeed.jpg
    Feb 2011
    Thanks Hoss. I have seen your website also and I have a question for you. What kind of vise did you use on your X2? The current vise that I have purchased from LMS extends over the table and because of that I'm limited with the travel. Do you know anything about some kind of small vise? The current one I have is : http://lmscnc.com/1699 . When I mount it on the table I can't turn it around because the mounting bolts are sticking out.
    Apr 2006
    I had a 3 inch LMS vise on my X2 but some folks squeeze a 4 on theirs. More ideas here.
    http://www.cnczone.com/forums/bencht...t_vise_do.html
    Hoss
    May 2004
    I want to emphasize that the recommended speeds and feeds you get from Machinery's Handbook, a tool vendor, or any other source are just that, a recommendation. You can think of it as a starting point. What actually works best on your machine, with your material, with your tool, with your tool holder, with your work holding, machining your part feature may be different than the recommendation. This is where years of experience comes into play. And this is where I can grab a number like 450 out of my head.
    As much science as there is in machining, there is still a lot of art involved. Craftsmanship. Artisanship. Even the way the sunlight is shining through a window at a certain angle can make a difference on how something machines from one day to the next. Make lots of sacrifices to the machining gods to help offset all these variable.
    Feb 2011
    Guys I set up the machine as:
    Feed 20IPM
    RPM 2500
    depth of cut .1875
    tool dia .375
    2 teeth
    When I start to cut the whole machine start shaking and go out of adjustment. I need to retighten everything after it's done. And also do a terrible job machining.
    Banned
    Mar 2009
    Do yourself a favor and get a subscription to Gwizard. You won't be sorry. There are many additional conditions to look at other then the basics you find on a feeds and speeds chart. Those charts are to get you in the ballpark.
    One particular setting you will need to account for with having a smaller machine, is the hp/weight ratio, which the Gwizard can calculate.
  • Page 1 of 3 123 LastLast
    1. Speed ,Feed & Depth of cut for Titanium
      By australia in forum General Metalwork Discussion
      Last Post: 06-08-2009, 12:22 AM
    2. Depth Cut Verses Feed Rate? 6 hr operation..
      By Rich05 in forum General Metalwork Discussion
      Last Post: 11-05-2007, 11:48 AM
    3. Optimizing Milling - Speed, Feed & Depth of Cut
      By palikalsi in forum General Metalwork Discussion
      Last Post: 04-03-2007, 05:59 PM
    4. Where's the Lathe Speed, Feed, and Depth Data??
      By Otokoyama in forum General Metal Working Machines
      Last Post: 02-06-2006, 02:14 PM
    5. Another feed rate, cut depth question
      By nervis1 in forum General Metal Working Machines
      Last Post: 02-10-2004, 12:56 AM
