Results 1 to 3 of 3
Thread: WMD-16V (BF-16) my version conversion to cnc
    Jul 2005
    Russia
    Read more here jager_f: (Russian language)
    Aug 2005
    Hi Jager - I like the motor mounts on the X and Y axis'. I can't tell from the picture how it is done.
    It looks like you turned the boss on the original motor mount to be an alignment pilot for the tubing the goes out to the flange that mounts the motor. If this is correct, did it automatically align the motor shaft and the screw shaft to the accuracy of the machine work? Is there a slot or hole to adjust the coupling?
    Thanks, Dave
    Jul 2005
    Russia
    Quote Originally Posted by Novah View Post
    Thanks, Dave
    The first clutch is fixed to the motor shaft, then clutch is fixed to the end of the screw is tightened, and through the slot in the tube
    Once the motor and the shaft are connected rigidly and centered, tighten the screws on the tide of the machine.
    For the alignment of fixing these planes are used
    Split sleeve compensates for the deviation of 0.5 degrees
    Translation using Google translator :-)
  1. My version of an X2 conversion.
    By SSfab in forum Benchtop Machines
    Last Post: 02-13-2011, 05:41 PM
  2. powermax 45 machine version vs hand version
    By landmark in forum Hypertherm Plasma
    Last Post: 02-14-2010, 05:13 PM
  3. Newest version of Mach3 Version 1.90.065
    By turmite in forum Mach Mill
    Last Post: 01-26-2009, 10:21 PM
  4. Replies: 2
    Last Post: 12-11-2006, 06:12 PM
