Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 50
Thread: G0704 setup as a lathe...
  1. #37
    Oct 2011
    Wow
    Nice thread! for the life of me ...shars needs to revamp there website... i looked for the R8 3 jaw chuck several times to no avail.... thanks for the Link!!
    got mine on order they are local to me about 45min drive...anyways its really amazing what you can do with these machines ....
    keep up the good work...
  2. #38
    Registered Connor9220's Avatar
    Aug 2010
    Quote Originally Posted by lcvette View Post
    For my initial testing purposes (don't laugh) i simply loosened the center and rotary bolt on the head and laid it flat on the table with a little bit of pressure pressing against it to hold it still. THen i tightened it down. this got it pretty damn close actually but i would venture that it could be wildly different depending on how parrallel the spindle bore in the head casting is to the flat side of the head i laid on the table. then i used a piece of hardened 3/4" stock in my boring bar holder and i brought the head and the stock together and adjusted the heights of both the head to get it off the table and the boring bar holder until it chucked squard in the 3 jaw chuck. once done, i removed the stock from the holder and put it in the chuck and got the runout to 0.000 and made sure it slid smoothly back into the boring bar holder and voila it went perfectly. that centered the boring bar for me. after that it was as true as i needed it to make a perfect taper and when facing the the surface was perfectly flat (at least i couldn't get .001" feeler gauge in it anywhere with a straight edge against it including trying the center.
    Not very scientific but it worked to get started. i am waiting on several gauges i ordered yesterday to make a tramming tool like hoss's and the other dual gauge tram tools out there. and will likely make somthing for when it is in lathe position as well. gotta think about that one but have some ideas.
    Chris
    Yea, I dropped mine down onto 123 blocks and locked it in.. Wasn't too far off.. but enough for me to notice. Come to think of it.. I have a hardened steel rod that's slightly smaller than .5".. I can't use it with collets, but, I could mount that up in a chuck and drop the Z down so that it touches 2 123 blocks (one close to the chuck, one toward the end)..
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  3. #39
    Aug 2008
    What treadmill motor did you get? I got mine today.
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    The brushes are parallel to the commutator but it seems to want to run smoother CW than CCW. I think it may be a timing thing. I may need to change the timing to make it a little more efficient in the CCW direction. I took the motor apart, looks like I can do it. The brushes on my motor look like they are uni-directional. Maybe they just wore in in a CW direction. I will do some more testing.
    I am a FSE in the semiconductor robotics industry so I have a ton of screws, linear rails, servo motor laying around. My friend is sending me a bunch of Yaskawa servo drivers, motors and controllers they have laying around at work. I am going to see if I can just go the servo route for the spindle. I see some other people doing it on youtube, looks pretty cool.
    Matt,
    that looks the same as mine with the exception of the horsepower rating. looks like yours is 2.4hp and 1.75hp continuous duty? mine is 2.8hp and 2.25hp continuous duty. but the frame is the same, both permanent magnet motors. try flipping the brushes to see if that smooths it out in CCW rotation. and take note on whether it is a tapered shaft or the pulley is reverse threaded on. Hoss's was reverse threaded and mine was tapered. with your lathe setup you can cut a taper in the timing pulley though.. very easy!
    very much looking forward to seeing the ballscrew results!
    Thanks Sk8Ter! yeah for some reason that tool is very well hidden on their website. i found mine in the catalog they sent me with an previous order and used the part number to find it online.. if i had to go back and find it through the website i doubt i could do it lol.
    post up when you get yours in and up and running!
    Connor9220,
    there ya go, I know little about machining, i am "winging it" so to speak... but each week i find new tools or gauges or something posted online that seems to help make better sense of it. machining is skilled trade and experience plays a large role, there are so many ways to do something that its not hard to learn it the wrong way or at least a much harder way then need be. ideally, I would like to be able to morph as quickly and accurately as possible between mill and lathe... and not have to manually change tools............ATC!!!!!!!!!!!!!!!! gotta have it! hahaha
    Chris
  4. #40
    Registered Bob La Londe's Avatar
    Oct 2008
    A buddy of mine handed me a 24 volt motor out of an Electric Mobility chair today. It made me think of this thread. I wonder what cool things I can do with it. LOL.
    I did test it on my truck battery and it seems to run fine.
    Bob La Londe
    http://www.YumaBassMan.com
  • #41
    Registered Turbo442's Avatar
    May 2011
    here is another test part turned on the mill.
    matt
    Attached Thumbnails Attached Thumbnails G0704 setup as a lathe...-sphere_test.jpg
  • #42
    Aug 2008
    Quote Originally Posted by Turbo442 View Post
    matt
    That is awesome, what feed rate are you using to get such a mirror finish and what insert? Also is that steel or aluminum?
    Nice work!
    Chris
  • #43
    May 2011
    Nice work!
    Chris
    This is 1" aluminum stock. I used the Mach turn wizard to create a 1" diameter sphere on the end. For the finish I cheated a bit... I did use a piece of 1200 grit sand paper and a bit of polishing from a Dremel while it was still spinning on the mill. The whole polishing process took a couple of minutes. I will make another cut so you can see the unpolished finish to compare.
  • #44
    Aug 2008
    hahahaha... i was wondering, i was thinking to myself... man i must be doing something terribly wrong, my finishes look good but not that good. glad to know i am probably in the vicinity of the norm!
    I am cutting out the motor mount for the new treadmill motor, once that is done i think its time for the ballscrews... i had one "minor" crash when my z axis stalled while retracting and then it tried to take a cut as if it were at the part Z sero location. luckily i decided to finish the motor bore in the block of aluminum with a boring bar and left myself .050", i was able to hit E-Stop before it went to far or losts its X and Y location.
    I'll post some pictures up when its done, but I think the ballscrews will help the stalling on the Z axis.. that and i have brough my rapids down to 40-ipm, it was running well at 50, but not gonna risk it.. may even drop it to 30-ipm for safe measure. the rapids done't speed anything up too much anyways, the cutting is still going to take a while. ( milling 1.5" thick aluminum block.
    Lunch time then back to milling!
    Chris
  • #45
    Mar 2011
    Quote Originally Posted by Sk8Ter View Post
    Looks like the 4" ones are actually gone from their site now. Knew I shouldn't have dragged my feet. Doh.
  • #46
    Aug 2008
    Quote Originally Posted by Mystichrome View Post
    you may want to try giving them a call, they may not have it in stock but at least they can tell you over the phone when they will have more in! worth a call!
    Chris
  • #47
    Mar 2011
    Chris
    I may do that, but I think it's gone for good. The 3" is still listed, but shows out of stock. They were probably clearing them out, which is why they were such a good deal. I'm probably better off building some kind of converted 4th axis or something, this just seemed like a quick fix to do light lathe work. Even if they do pop back up, I'll doubt they'll be at the same price and I have a problem spending more when I know I could have had it cheaper. Not getting it isn't the end of the world, just irritated with myself. I kept eyeing it, but there are so many necessities I still need to get that I kept saying 1 more week. Not the first time this routine came back to bite me and I'm sure it won't be the last.
  • #48
    Aug 2008
    I know what you mean, you are probably right, that price must have been a clearance sale, I wonder if they had a big inrush of orders for it recently with the thread having the link in it. if so they may bring it back.. but like you said it won't likely be at that price. I am sure you could make one for about the same price at least... I hate you missed the sale. if i see anything else like it around the same price I will shoot you a PM on it!
    Chris
  • Page 4 of 5 FirstFirst 12345 LastLast
    1. CNC Lathe setup
      By mroy0404 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 04-24-2011, 10:44 AM
    2. Boxford TCL 125 Lathe setup
      By SKennedy in forum LinuxCNC (formerly EMC2)
      Last Post: 03-07-2011, 03:34 PM
    3. D&M 5 Lathe setup
      By afaiello in forum Mini Lathe
      Last Post: 04-22-2009, 06:43 PM
    4. Old lathe spindle setup
      By PIngels in forum General Metal Working Machines
      Last Post: 12-06-2006, 11:15 AM
