After a lot of investigation, I believe I've found the main cause of the stiffness, and noise: The shoulder of the leadscrew has a small 3mm spacer resting against it, however the shoulder itself is turned directly from the thread, so it is uneven. When I tension my bearings, it is causing shaft deflection, and is not free running. Cheap, nasty, Chinese build quality :/
Options for me:
1) Machine a new shoulder
2) Use a tight fitting, and longer spacer, which cannot be skewed
3) Use a clamp-on collar instead of the spacer
4) Replace leadscrew altogether
LinkBack URL
About LinkBacks
