Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Any Experience With This Company?
    Nov 2011
    Anybody have good or bad experiences working with this company?
    UGRAcnc
    Thanks,
    GG67
    Dec 2005
    Quote Originally Posted by GG67 View Post
    UGRAcnc
    Thanks,
    GG67
    Andy at ugracnc is awesome. I ordered a 2.2kw watercooled spindle, a momentary on/off power button, estop, and some 18power wire from him.
    Obviously the spindle was more than the china sellers on ebay. Andy personally powered up my spindle and checked its runout before sending it to me. Then he did the ultimate thing - he made a video of MY SPINDLE and put it on youtube and sent that to me before shipping it out. How awesome was that??!! That is the biggest RISK I have read about on the spindles is what if it does not work or has issues when it arrives.
    Andy gives a warranty on his spindle if they are bought direct from his site. Thats what I did. He is also in Pensylvania and you can call and talk to him if you have questions. That was my second issue with buying a spindle from China.
    His 2.2kw spindle came with a larger connector on it than most but I still changed it out to a amphenol ecogate connector from digikey - thanks to GaryD for that recomendation. I do not like soldering those little cups on teh chinese connectors. His does have four pins on it - only the three motor ones are used so you can add a ground to the 4th.
    His power buttons and estops might be the best deal I have found for an E stop. I have been using them on my friends controller builds I do for them since I have found them. I also like his limit mechanical switches and all I have tried have been the cheaper red one. He sells what look like much nicer ones than those.
    His 18ga power wire is shielded and I use it for the home/limit switches. I bet you could use it for power wire on teh spindles. I choose to go with Igus CF31 16ga 4 conductor powere wire - that is the best power wire for a spindle on a cnc machine I have found. Thanks to diyengineer I think that gave me that power wire recomendation.
    Andy and I have become online friends and talk every couple weeks. He is a cool CNC seller and I keep on him to keep this niche of providing spindle checkout pre sale support. I think that is SOO worth what little extra he is charging for a spindle. By the time I was into buying the 2.2kw for my machine the extra coin was not an issue.
    Also, I have been on him to sell Hitachi VFDs I am a fan of the Hitachi x200 022nfu2 VFD I bought for his spindle. Diyengineer also sent me to that VFD. Thank you DIYEngineer!
    Andy rocks and I hope he continues to sell parts and expands his line up.
    He also has a machine for sale on ebay that looks very very heavy duty for a smaller ball screw machine!
    Here is the spindle I bought from him cutting a paradise box top - a free vectric vcarve pro file that Mike gave the community - Thanks Mike!!
    http://www.youtube.com/watch?v=Gs2l51y3o2w]Spindle cutting Megans Jewelry box from some free Vectric Files - Thanks Michael for making those! - YouTube
    Here is the walk around of my spindle setup. I added the spindle to my castcnc setup so thats why I added a nema box.
    http://www.youtube.com/watch?v=x24rP5n0RNw]Modbus controlled Hitachi X200 VFD, 2.2kw 3Hp Chinese Spindle, Spindle Water Cooling all installed! - YouTube
    Joes 4X4 R&P, CastCNC v2, K2 8" Z, Vrail, and 2.2kw spindle and X200 w/ Modbus
    Nov 2011
    Thanks for the thorough reply. I will definitely be considering UGRAcnc for my project.
    GG67
    Dec 2011
    Quote Originally Posted by BloomingtonMike View Post
    I have been trying to find this ecogate connector and am not having much luck. This is the only post on cnczone that mentions ecogate, and a search of digikey for ecogate returns nothing. If anyone has more information on these connectors like part numbers or a specific ordering link it would be enormously appreciated.
    BobC
    Registered holbieone's Avatar
    Feb 2007
    Dec 2011
    Yes thanks, that helps a ton. It is ecoMATE not ecogate...
    I had been on the first link....but they were all male connectors and none were blue, that's all a search for ecomate returns on the Digikey site for some reason.
    The PDF was the eye opener.... Saw the Female connectors Blue and Black and then searched by part number and BINGO!!
    Not sure why they didn't get listed with a search for ecomate....
    Anyway thanks again!!
    BobC
    Dec 2011
    Ok, now I'm confused again...
    I ordered the part from DigiKey 361-1362-ND CONN FEMALE PLUG 3+PE GOLD BLUE.
    It looks right, but the 4 female plug holes are 1/4" apart. The pins on the 2.2kw spindle I got from Ugracnc are about 3/16" apart....the plug won't fit. I don't see anything on the datasheet specifying that dimension.
    Anyone have any ideas?
    Thanks!!
    BobC
    Dec 2006
    I looked at th elistings and if you click on the PDF at the bottom of the listing there is a little info. The only two things I seen that might help with size was by measuring the diameter of the connector itself, and possibly wire size also may determean the over all size. Really it looks like if the outside siameter was right then it would be right but IDK.
    Also one other thing was they are either soldier connectors, crimp, or screw connectors. This would be something to help go by also.
    Jess
    GOD Bless, and prayers for all.
    Dec 2011
    Thanks for the reply Jess.
    Yea, it's definately strange...the diameter of the connector is actually correct, just the hole/pin spacing is wrong. And I also thought maybe the different connection types would make a difference but couldn't find any indication that screw connected pins would be spaced any different than crimped....for now it is a mystery...
    Worst case I'll bite the bullet and solder on the connector that came with the spindle...not exactly my fortay...
    Dec 2005
    Quote Originally Posted by bobcam300 View Post
    BobC
    I just now read this sorry.
    Here is a male part - you order male and femal plugs seperately. click their catalog to see the other parts.
    Digi-Key Part Number361-1345-ND
    Digi-Key Part Search
    Dec 2005
    Also just so everyone knows, I changed out my receptical in my spindle too. I drilled out the spindle cap and installed the amphenol ecomate receptical in the spindle and attached a ground wire inside as well.
    Here are more part numbers as of 11/12/2012.
    361-1345-NDCONN MALE PLUG 3+PE SILVER BLACK3 (black plug)
    361-1344-NDCONN MALE PLUG 3+PE SILVER BLUE3 (blue plug)
    361-1081-NDCONN FMLE RCPT 3+PE SCREW SILVR6 (black receptical)
    Here is change over of receptical.
    Take off cap and remove old receptical.
    Drill out cap for receptical and mount holes.
    Put wires through cap and install receptical
    Connect new ground to mounting screws - I provided my own screws.
    Pic of installed receptical and plug attached.
    Jan 2007
    i purchased nothing from them yet..
    however i got help..
    i had a single phase220 input inverter with a 1.5 kw spindle..
    their pdf helped me figure i can wire the 2x110 properly, because inverter recognize automatically the input voltage..
    thank you..
    sure these products need some domestic distributor and its help..
    spindles itself working very well..
  • Page 1 of 2 12 LastLast
    1. Company wants to buy first cnc
      By DWAS in forum Want To Buy...Need help!
      Last Post: 10-06-2010, 10:07 AM
    2. UK COMPANY/CNC
      By haasmanuk in forum Product and Manufacturer Announcements
      Last Post: 02-23-2010, 08:47 AM
    3. Just IN- New Company in NZ
      By nztomcat in forum Australia, New Zealand Club house
      Last Post: 10-19-2009, 08:22 PM
    4. Just IN- New Company for work
      By pyroshizzness in forum Product and Manufacturer Announcements
      Last Post: 07-17-2009, 01:48 PM
    5. Company name suggestions
      By arvidb in forum CNCzone Club House
      Last Post: 11-16-2004, 05:55 PM
