Results 1 to 5 of 5
Thread: So, with Mach3 you have six axis capabilty, right?
    Dec 2010
    And the motors and drivers don't really care what stuff is named...
    So... Could I run X, Y, Z and W to a mill, and two other axis to a small lathe, all from the same computer/controller enclosure? Some extra wiring, but I'm guessing it might be a little less complicated than two controllers, two computers, etc?
    Jan 2006
    Having them simultaneously connected would be a PITA. You will have a lot of headaches with limit switches, etc. Just lots of unnecessary complication.
    If you really want to do that, I'd recommend using one computer and have 2 different mach configurations and just plug in the parallel port for the machine you are wanting to use. Then both machines can use the same limit switch inputs, etc.
    Matt
    Feb 2008
    Two 3 or 4 axis controllers is going to cost you roughly the same amount as 1 6 axis controller (especially if you use the G540). You'd also need two parallel ports for that setup. So you might as well have two controllers.
    The other option would be a single controller and unplug the motors and limit switches when changing configurations. That is more error prone, but workable.
    Mar 2003
    Shelby Twp, MI....USA
    If you use different profiles, and different ports, you don't need to unplug anything, unless you need more than 1 port for either machine.
    Aug 2008
    I use one computer to control a plasma table, a mill and a lathe, i have a parrallel port switch box:
    4-Port DB25 Manual Switch Box
    to select between which Break Out Board and driver box to use. I share a 48V power supply between the three as well to cut down on cost. I have the DC output from the PS on 3 seperate switches, Mill, Plasma, Lathe but you MUST be carefull to select which you want to power prior to turning on the power supply, it can hurt the BOB if you send a rush of DC current through the switch while the PS is turned on. So i select which machine i will be using on the power supply box via the DC power switch. then i select the machine on the parrallel port box, then i turn on the control box for that machine (BOB power) then i turn on the power supply (AC voltage supply).
    Then on the computer I have Mach Turn, Mach Mill and Mach Plasma, open the appropriate one for the machine you will be using and viola. saved a good bit of money on having to buy 3 $130 power supplies.
    and you don't have to fiddle with pluging and unplugging cable in the back of the computer, very neat and clean setup!
    Hope that helps!
    Chris
  1. Need Help!- How to reverse Z and X axis in Mach3 ?
    By master_bebe in forum Mach Mill
    Last Post: 01-25-2013, 11:59 PM
  2. Need Help!- Mach3 A axis (4th axis) setup?
    By cadcamslawek in forum Mach Software (ArtSoft software)
    Last Post: 01-17-2012, 09:23 PM
  3. Need Help!- How to assign 5th & 6th Axis to Slave when Pin 2-9 already used in 4 Axis for Mach3
    By guy2b1 in forum General Electronics Discussion
    Last Post: 10-29-2009, 09:09 AM
  4. Newbie- Running Mach3 with only X&Y Axis
    By kae in forum Mach Mill
    Last Post: 12-31-2008, 05:21 PM
  5. problem with my z axis on mach3
    By thesaent14 in forum Machines running Mach Software
    Last Post: 04-06-2007, 06:28 PM
