Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: Micro Mill CNC Conversion
    Apr 2003
    Paris, Texas
    Thumbs up Micro Mill CNC Conversion
    I recenty bought a Micro Mill, CNC Fusion Kit, and the Hobby CNC package. I have the mill cleaned up, and the cnc kit installed. I got the electronics working as well. I amaze myself sometimes :-)
    Should I run 1/2,1/4,1/8, or 1/16th step mode?
    What I need to figure out now is my steps per inch? Can some assist me there?
    200 * step mode * X = steps per inch
    But what the heck is X?
    Donald
    Registered drawbar's Avatar
    Apr 2004
    X is the pitch of your leadscrew in threads per inch. Say, for your X axis that it is 10 TPI, and that you have your driver set for 1/2 step mode. Then you have:
    200 * 2 * 10 = 4000 steps per inch
    Brian
    Apr 2003
    Paris, Texas
    Correct, but what is the TPI on the Micro Mills. I have been told the X & Y is 20 TPI and the Z is ABOUT 1.5mm
    Donald
    Jun 2005
    congratulations on your purchase.
    I have the Micro mill and the HobbyCNC driver board (not package). I made and modified the existing hardware on my own for the CNC hardware as it cost me under 50 bucks for that as opposed to 300 for the CNC fusion. But the Fusion looks like a nice kit.
    You pick the step mode by adjusting the jumpers on the board, its based on how much noise and vibration your getting from the motors. I am using 1/8
    What is your software? Is it TUrboCNC? If it is, TUrboCNC has a calculator where you enter;
    Steps per revolution for the motors
    Microsteps
    leadscrew TPI (which is 20TPI or it advances .050 per revolution).
    The micro mill makes a nice conversion, and be sure to get the Y axis extension kit from Little machine shop sometime, it transforms the machine!
    Apr 2003
    Paris, Texas
    Quote Originally Posted by phantomcow2
    Microsteps
    So you are saying the leadscrews on a Micro Mill is 20 TPI?
    I am using Mach 3 Demo currently. Will purchase soon as I get all the bugs worked out I am thinking.
    Donald
    Jun 2005
    Well some say they are metric. And its quite possible, all I know is that when i put my dial indicator on the table and test the movement of one revolution, its RIGHT ON .050
    This is what 20TPI gives you, so for all practical purposes, its a 20TPI screw
    Apr 2003
    Paris, Texas
    I was just running my steppers to make sure they moved good, and I am having a issue with the Z axis. Some times it stopers turning with a awful noise from the stepper. I first thought the lovejoy connectors where turning on the shaft as I have not put flats on the yet, but to find out that is not it. The steppers are just not turning.....like not enough power or something. I slowed it down from 200 t0 5 and it still happens. I have 200 Oz steppers from Hobby CNC. The X & Y where doing it to, but I slowed them down, and it stopped there. Is the 200 Oz just to weak for the Z or do I have something wrong.
    HELP!!!!!!!!!!!!
    Donald
    Jun 2005
    First of all, make sure the voltage is set accordingly. YOu need a digital multimeter and refer to the VREF chart that came with the HobbyCNC board. Then if theres taht awful noise, try running 1/4 microstepping
    Apr 2003
    Paris, Texas
    I already tried 1/4 step, still there. I will double check my vref's. I had them at .54 when built the board, but I will check again.
    Donald
    Mar 2004
    You may have your motor acceleration set too high. If you don't allow enough acceleration time, and don't account for the load on the stepper, it will stall before it even gets moving. If this is the problem, you'll have to decrease the acceleration rate in Mach3. It's under the motor parameters or motor set up.
    Keith
    Nov 2004
    Are you counterbalancing your head? If not the z axis motor might not have enough force to move the head up. I looked at the fusion kit to check, and didn't see an air spring or any pulley system for counterbalancing, so I am assuming you haven't. You might want to do that before you mess with the steppers too much, may never get the acceleration low enough for it to work properly with that much weight.
    Apr 2003
    Paris, Texas
    That makes sense......but it will run fine for a few inches then stop. It is only happens on the higher part of the Z axis....I have checked and it turns free by the handles...
    I will check that setting and see if it helps any as well.
    Donald
  • Page 1 of 2 12 LastLast
