Do they have grease fittings? A general purpose lithium grease is fine if they have grease fittings or locations to install grease fittings. Way lube, of course, is fine but you need some way to provide a constant very slow feed when the machining is in use. This is why grease can be easier.
LinkBack URL
About LinkBacks
