Results 1 to 12 of 12
Thread: Chinese made tapping head - thoughts?
    Registered ninefinger's Avatar
    Sep 2006
    Hi Guys,
    I have a bunch of small holes I'm going to be tapping - in the M2 to M4 range or 2-56, 4-40 etc.
    I'm looking at my options for tapping and from what I've read so far it seems that some people with converted machines are having better luck with the auto reversing tapping heads versus the Tension / Compression heads that require spindle reversal.
    So that is what I'm looking for - an auto reversing tapping head. My question: does anybody have experience with the cheap "tapmatic" knock off tapping heads sold by various ebay sellers or Shars (discount_tools), etc? like this one: 1/4" REVERSIBLE TAPPING HEAD NEW MACHINE TAP | eBay
    Does the reversing ratio matter much (some are 2:1 some are listed as 1.6:1, etc)
    I have the space for it on my mill (the MD001 - super siize RF45) as I have 18 inches of Z travel so that part doesn't matter.
    Mike
    Feb 2006
    Unless you're doing very small threads, I would suggest you use thread milling, rather than a tapping head. It's quick and easy.
    Regards,
    Ray L.
    Aug 2008
    Mike,
    I have a tapmatic knock-off in the larger size (up to 1/2")
    Haven't used it with CNC yet, but I've used it plenty on the manual mill & I love it.
    Dec 2009
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    You know a source for reasonable cost thread mills? Been thinking about that myself. Making a small tooling plate soon and tapping 44 3/8-16 holes would be much nicer if I could just thread mill them.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    ninefinger,
    I have a "Taco" knockoff which I believe is made in India. I recently had to do 50 M3 holes for a router that I am building. Busted one tap because I did NOT properly setup my cam program. But after I got that sorted out all the rest of the holes went perfectly. Matter of fact still using the same tap!
    the only thing you really need the reversing ratio for is when your going to do this process by cnc so you can get the feeds right and not either pull the tap out of the holder of strip threads because your going to slow! See above! I busted my tap because I had a wrong setting and it was pulling the tap out of the holder and all of a sudden the tap did not come all the way out before it tried to move to the next hole....scratch one tap:{(
    Art
    Nov 2009
    Quote Originally Posted by photomankc View Post
    I really have no idea what a "reasonable cost" is, but here is one for 16UN threads....depends on the depth you need.
    Xactform solid carbide thread mill CNC mill die mold shop TMN1/4x0.240 16 UN new | eBay
    I think the same seller has another 16UN thread with 3 spiral flutes and a depth of about .750..but it is a little more expensive ~$100.
    Gonna have to look into these..never really used them before. I like the idea of the multi-tooth versions for speed, but the single tooth sounds nice because it can do any pitch.
    I have the smaller TapMatic. I've liked it for the little amount I've used it. You can go right back into a tapped hole to make it deeper if it clutches out on you.
    Not sure how that works with the reverse ratio and CNC? Guess you have to modify the retract feed rate? I think the reverse is just to get out of the hole faster for faster overall cycle times on many holes -
    -Doug
    Mar 2004
    LaGrange, GA USA
    Doug,
    "Not sure how that works with the reverse ratio and CNC? Guess you have to modify the retract feed rate? I think the reverse is just to get out of the hole faster for faster overall cycle times on many holes -"
    Yes, I believe your correct. Also on cnc, you have to program in the appropriate distance for the clutch to work for reversing. My cam program wanted the max travel rate and that is what screwed things up for me. I inserted a little less than half and it works fine. This would be especially important if your doing blind holes!
    Art
    Dec 2009
    Ah-ha I found this. Good source for thread mills that don't cost a fortune each. Now to figure out how to produce the code for EMC2.
    Thread Milling
    Banned
    Mar 2009
    Another thread mill source, that is decently priced.
    Lake Shore Carbide
    Sep 2006
    Well as nobody shouted "don't do it" I went ahead and ordered the one I linked to in my original post. Thread milling seems interesting, especially for larger holes and in tougher materials but for what I have lined up a tapping head makes more sense. Simple G code or even manual operation on a drill press, pick your tap and away you go. At $40 per thread mill staring price I can see quite the investment to collect all the proper pitches needed for a job shop type environment and that still does not cover below 2-56 or M2.
    Thanks for your opinions guys - it pushed me over the edge. Now onto shopping for a larger lathe....
    Mike
    Dec 2010
    Ah, but break a few taps, and...
    If you can't rescue them, you throw parts away, and since a lot of them here have more $$ in them than the tap...
    We've got tapmatics, but if you can find something that is reliable and Bogie-proof, go for it... I'd rather tap and be done than deal with the CNC stuff with most things... The cutters can do oddball stuff tho, where the taps can't...
    Jul 2011
    china
    Can you tell me the difference bettween the laser cutting machine and the milling machine?
    Quote Originally Posted by ninefinger View Post
    Mike
    1. New Machine Build- chinese:rails/bearings/drives your thoughts plz
      By vdoug in forum DIY CNC Router Table Machines
      Last Post: 03-12-2013, 04:23 PM
    2. Shop disagreement on rigid tapping, your thoughts?
      By Chriseg1 in forum Haas Mills
      Last Post: 11-07-2011, 03:40 PM
    3. Reversing Tapping head vs Tension/Compression tapping Head
      By apeman88 in forum Tormach Personal CNC Mill
      Last Post: 01-25-2011, 09:39 AM
    4. Newbie- Initial thoughts on tapping
      By LuckyStrike in forum General Metalwork Discussion
      Last Post: 07-17-2008, 11:39 AM
    5. tapping head vs hand/cordless tapping machine....
      By InspirationTool in forum General Metal Working Machines
      Last Post: 09-12-2005, 09:10 PM
