OK. So payday is coming up, and its time for the next round of part orders.
Also, the C11 will be getting exchanged for a
C32 BOB.
Here is my list so far:
Mach 3
Emergency Stop - CNC4PC RJ45 Limit Switches
Oldham couplers: ?
I believe I need 16mm to 1/4" and 20mm to 1/2". Still trying to find these.
Anybody have a suggestion?
It looks like I might be able to use 1/4" to 5/8"(1/4" to 16mm NEMA 23 X and Y) and 1/2" to 3/4" (1/2" to 20mm - NEMA 34 Z). RJ45 Connector for Keling Digital Driver Pro Tram System Grizzly Clamping Kit Quick Change R-8 Collet Set:
Is this ok? Dial Test Indicator Magnetic Base Dial Indicator
Any recommendations on a 5" vise?
LinearMotionBallscrews/Ballnuts:
Is it possible/beneficial to run a double ballnut configuration?
Parallel Cable, On/Off Switch, enclosure, wire, and Ethernet cables will be picked up locally.
I have a couple computers I will be trying out with parallel ports.
Please chime in with your opinions on everything here, I can sure use some guidance.
If I am missing things (which I know I am), please let me know and I can order them up for the next round.
