Results 1 to 3 of 3
Thread: Mill Drill Z axis Counter Weight
    Registered Need TECH Help!'s Avatar
    Dec 2007
    U.S.A.
    Hello all,
    Been putting this off for a while now. I need a little advise on where to anchor the Z axis counter weight to the Z axis. Counter weight will be aprox 125 to 135 lbs. Machine is a RF45 type mill drill that i designed the Z axis. Here is some jpgs of my CAD design.
    Not sure if i should anchor just behind the spindle head(bridgeport type), or right in front of linear ways.
    Any help is much appreciated.
    Thanks,
    Troy
    Attached Thumbnails Attached Thumbnails Mill Drill Z axis Counter Weight-mill1.jpg   Mill Drill Z axis Counter Weight-mill2.jpg
    Banned
    Mar 2009
    Is a counterweight necessary? You should be able to put a stepper/servo motor on there with the right pulley reduction so that a counter weight is not necessary.
    Also, if your set on the counterweight setup, take a look into gas springs. Much easier to retrofit and look nicer too.
    Dec 2007
    U.S.A.
    I have no problems with the stepper handling the load. The reason for counter weight on my setup, is to take a lot of stress off of linear rails,ball screw,etc. Plus it helps in taking out some vibration when cutting.
    I have looked at the gas spring setup, but prefer the weight setup.Plus no brackets or nothing would be in my work envelope of machine.
    Thanks,
    Troy
  1. Vertical mill counter weight chains
    By BJSwart in forum Maintenance DIY Discussion
    Last Post: 09-21-2011, 05:07 PM
  2. feedback on a Z axis kit for a knee mill and mill drill
    By extsuba in forum Vertical Mill, Lathe Project Log
    Last Post: 03-31-2009, 07:06 PM
  3. Need Help!- locking down head and counter weight on 15XT
    By diemaker76 in forum Fadal
    Last Post: 03-13-2009, 09:38 AM
  4. My mill/drill Z-Axis design
    By jimjovan in forum Vertical Mill, Lathe Project Log
    Last Post: 11-16-2008, 06:49 PM
  5. Need Help!- Counter weight
    By David Russell in forum Fadal
    Last Post: 10-03-2008, 10:59 AM
