.............I have gone back and forth on plans, sizes, costs...
Goal
The machine will need to cut steel
The quill Z needs to be greater than 4"
Variable Speed.
I would prefer to have a machine that is not sourced in China, but that may not be realistic.
Square column or Knee Mill design.
Wanted Options either installed or down the road
3 axis DRO
Power Feed for X,Y,Z
enough space to use a 4th axis rotary table
Usage
Um... hobby mill, I don't know if I will ever
CNC it, however if I do, I will want to be able to do some limited manual work still, otherwise I will just have a friend do the
CNC work. So, the requirement to have room to work and use a rotary table is probably the largest requirement.................I currently have Alibre Expert for design work..........
Thoughts and other wanderings..............PM45 I was planning on getting a PM45 with variable speed head, DRO, power feed, and powered X axis, which totals about $5k plus a stand. IH version..............I am concerned about their supply issues and that they are reportedly too busy to return calls and email. But I have talked to them on the phone. Chinese sourced............particularly the Jet JTM-4vs-1. The problem is I end up with just a Knee mill with VS, but none of the rest of the goodies and it cost 50% more for the privilege.
Conclusion
And so I go round and round trying to decide the best course of action as I read and gather data, luckily for me, I don't have the money sitting and burning a hole right now, so it will likely be at least a few months before I have to decide. Any input would be appreciated.
