Results 1 to 7 of 7
Thread: Mt2 Collet Wrench for X-1 Mill
    Aug 2008
    I want to post how I installed ball screws in the X-1 micro mill but I'm not quite ready so I've got something here that I hope will be of interest. Also, I'm having a lot of problems posting pictures here from "Photo-Bucket", they seem to have changed things sense the last time I used the. I think I have it figured now out so here goes.
    A year ago or so came up with a Quick Change Tooling system for the X-1 micro mill. See below photo:
    I used the Tormach type of holders but using a .500 collet instead of the .750 they use. Here are a couple of drawings of the rig:
    With this setup I needed to adjust the draw bar top length so it meets properly with the cam lever. That meant I needed to adjust the collet while it was in the spindle so I used an old computer case part but it didn't work very well:
    I decided to make a M-2 collet wench, similar to the ones I see for 5c collets.
    More to come:
    Aug 2008
    Mt2 Collet Wrench for X-1 Mill #2
    Here's a drawing of what I wanted to make:
    I made the blank out of A-1 Drill Rod on my manual lathe:
    I'll use the cnc X1 now to cut the wench part. Here is the path I plan to use for my g-code:
    In this photo, I'm using an old fashion type edge finder to get the part set up:
    Here's getting the Z-Axis set:
    Now the mill's starting to cut the part:
    Aug 2008
    Mt2 Collet Wrench for X-1 Mill #3
    I ran into problems here. The 1/8" 2 flute HSS end mill was having problems cutting the Drill rod. I was making a lot of racket leaving a bad finish so I decided to change to another end mill. I don't like doing this but I was only half way down and the (used) HSS bit looked like it was going to brake. Anyway, I changed to a new 1/8" 3 flute carbide bit and continued to cut.
    The new end mill worked great, I should have started the cut with it.
    This is a photo of the finished part:
    This is the two bits I used. The new carbide end mill is on the right:
    I had to clean of the wire edges with little files and I put the 1/2" guide into the part. The collet wrench will only be used with a 1/2" collet, so the guide will make it easier to use.
    Here is the wench part with a M2 collet:
    I'll try to finish this up in the next post.
    Aug 2008
    Mt2 Collet Wrench for X-1 Mill #4
    Almost done. I made a handle for the wrench out of 1 inch "Acetal". I was going to harden the part made of drill rod but I don't think it will be necessary. I guess I find out later. I think I'll need to pin the part inside the handle so it won't spin. I'll do that later:
    Here it is with a collet:
    And here with the X-1 Mill spindle:
    Gold Member hoss2006's Avatar
    Apr 2006
    Very nice work Tex! Keep it coming.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Aug 2008
    Mt2 Collet Wrench for X-1 Mill #5
    Thanks Hoss,
    I appreciate the kind words.
    I finished up the little collet wench today.
    I wanted to pin it so it wouldn't spin in the handle. As it turns out the length need to be a little shorter to have it fit into the tool holder box that goes with this mill. Also, I think it looks a bit better like this.
    Well, that's it for now. I hope to start making another set of ball screws for the X1 next week. I'll write up and post my method of getting then installed. It was quite a chore but I have them in 2 mills and so far so good.
    I hope you all have a happy holiday. --------- Tex Rubinowitz
    Oct 2008
    U.S.A.
    Good work and nicely documented!
    Rich
    1. ER40 Collet Wrench for ER 40 Collets
      By CNCadmin in forum EBAY ADS
      Last Post: 07-07-2011, 08:40 PM
    2. ER20 Collet Wrench for ER 20 Collets
      Last Post: 05-30-2011, 11:10 PM
    3. ER20 M Style Collet Wrench
      Last Post: 05-27-2011, 05:10 PM
    4. ER20 M Style Collet Wrench
      Last Post: 04-16-2011, 04:00 PM
    5. ER40 Collet Wrench for ER 40 Collets
      Last Post: 04-16-2011, 02:10 AM
