Results 1 to 8 of 8
Thread: My version of the air ratchet drawbar
    Registered kregan's Avatar
    Mar 2011
    Hi Guys,
    I decided last week to go with Tormach TTS tooling so I needed a powered draw bar of some type.
    My machine is a round column and I have the ball screws driving the quill directly so any system that put a lot of down force on the draw bar was out.
    With suggestions form the group in another thread I decided to use the 3/8" butterfly ratchet from Harbor Freight. It cost $25.00. I had to mount it to the belt cover so I could still open the top when needed. I used 3/8" id bushings and some old R/C car springs I had laying around. It works great, thanks for the suggestions guys.
    Attached Thumbnails Attached Thumbnails My version of the air ratchet drawbar-photo_1.jpg   My version of the air ratchet drawbar-photo_2.jpg   My version of the air ratchet drawbar-photo_3.jpg   My version of the air ratchet drawbar-photo_4.jpg
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    Wow that was quick. Glad you got it solved and that it worked out. =]
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    Tinkerer
    Nov 2009
    The pictures wont enlarge for me. All I get is a black screen once a picture is selected. I would like to see this bracket in detail, though it looks simple enough. You say you mounted it on the belt cover? I am missing something, isnt the belt cover plastic? OTOH you are using a conventional drawbar and not the belleville washers ala Hoss, right?
    Registered Connor9220's Avatar
    Aug 2010
    Quote Originally Posted by kregan View Post
    Hi Guys,
    Can you shoot a video of it working and how it interfaces with the drawbar itself ?
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
    Dec 2006
    It looks pretty simple, appears like he just grabs the gun and pushes the whole assy down by hand ( look at the light springs). So when he pushes it down the socket on the end goes over the draw bar and he hits the trigger.
    Cutting angles on the top edge of the draw bar nut would allow the socket to engauge it while spinning with downward pressure was applied so it would automatically slip on when used.
    His may not have angles cut this way, and it doesnt have to be but it helps alittle to cut angles in either the drawbar nut or the socket. They dont need much just enough to guide the socket on the nut, and only for one dirrections (loosening).
    You can see a second plate on the bottom of his upper plate, this has set screws in it to lock down on the gun. It may be milled out this way instead of a added plate but you can see the raised (lowered in this case) section on the bottom of the upper plate.
    His belt cover appears to be stamped steal ( sheet metal). If your cover is plastic you need to guage how strong it is. The springs used to hold up the gun are light, and thats all they need to do is be able to return the gun after pushing it down, no more. With a plastic cover adding a spreader plate under the assy would help. Maybe making it big enough for it to reach out to the outer edges of the cover where there is more support. Of course you would have to judge if your cover has enough strength to hold up, and a spreader plate, with the right size springs would help you get there. Its not like the gun locks onto the drawbar, it just floats on top of it so there is no added stress other than what it takes to push the gun down to the drawbar. This is very little and even plastic should hold up with the right prep and spring size.
    The butterfly type gun such as his makes revearsing the dirrection easy. So using this setup would be very simple in practice (and fast).
    Jess
    GOD Bless, and prayers for all.
    Mar 2011
    I can shoot a little iPhone video later and post it.
    My belt cover is steel so the mount is bolted to the cover with four 8/32" socket cap screws.
    The upper plate is made from two parts of 1/4" aluminum simple because I did not have any 1/2" scrap around. A pair of 6/32" set screws hold the gun in place on the upper mount.
    I am attaching the DXF file if anyone wants it.
    Operation is simple, grab the gun, push it down, rotate the butterfly lever the direction you want it to spin. My machine is pretty small so it is always easy to reach and there is no enclosure so I did not need a remote air switch to activated it.
    Attached Files Attached Files
    Tinkerer
    Nov 2009
    Pictures work fine now? Weird. Nice job.
    Mar 2011
    Short video for Connor9220
    http://www.youtube.com/watch?v=a5mZa9JklH0]Air Ratchet Power Drawbar - YouTube
    1. Newbie- Tips on drawing Ratchet/Pawl?
      By binfordw in forum BobCad-Cam
      Last Post: 04-21-2011, 08:30 AM
    2. Power Drawbar - My Version
      By saabaero in forum Tormach Personal CNC Mill
      Last Post: 03-18-2011, 05:04 PM
    3. Ratchet/R-F stop micrometer
      By fpworks in forum Calibration and Measurement
      Last Post: 02-04-2007, 11:54 AM
    4. Replies: 2
      Last Post: 12-11-2006, 06:12 PM
    5. Ratchet or Ratchet-Friction stop micrometer
      By fpworks in forum General Metalwork Discussion
      Last Post: 08-22-2006, 11:47 AM
