Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: what are they used for
    Oct 2009
    This stuff came with my little RF20 Sears mill. The box of flat stock looks like shims, possibly for the ways??? The other is a collet, but what are the parts under the collet for? And then there is the 2-4-6 blocks, what is the intened use of these blocks? Oh, the collet will not fit the machine, it's R8.
    Attached Thumbnails Attached Thumbnails what are they used for-shims.jpg   what are they used for-collet.jpg
    Gold Member hoss2006's Avatar
    Apr 2006
    The parts in the first pic are parallels, used mainly for supporting stock in a vise but
    can be used for much more.
    In the 2nd pic with the 2-4-6 blocks (look more like 1-2-3)are 5C (most likely) collet fixtures
    Used for holding round or hex or square stock depending on the collet, also in a vise most times.
    Allows you to easily flip the fixture in the vise and miill up to 4 or 6 sides.
    The blocks are used for setting up or supporting stock too.
    Very useful tooling that can be used in multiple ways.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Oct 2009
    yea 5c 3/8 and it does fit inside the dodads under it. So it would only hold a 3/8" something, and in a vice. Seems useless at this point. thanks, and nice vids on youtube.
    Apr 2006
    You can get 5C collets to 1 1/8 inches by 1/64ths plus machinable blanks to 6" and internal and external,
    and for different shapes.
    Very valuable for stock holding but can get expensive for complete sets.
    Hoss
    Tinkerer
    Nov 2009
    Quote Originally Posted by scottd View Post
    You will quickly find that tooling and workholding will be the most expensive and time consuming part of machining. Do not throw these parts away or sell them, as soon as you know what you are doing, you will need them. Kind of like doing your first cnc rehab, you gut the machine because you dont know what those old electronics do. Soon you start seeing the parts were very similar to the replacements you are installing.
    Registered lancut's Avatar
    Nov 2008
    "Do not throw these parts away or sell them, as soon as you know what you are doing, you will need them."
    Yea, what he said. As soon as you figure what you doing... you gonna use those parts often!
    Forget about global warming...Visualize using your turn signal!
    Oct 2009
    Quote Originally Posted by lancut View Post
    I'm not going to have much us for a C5 3/16 collet and a holder. 2-4-6 blocks, kinda useless as well. The guy that used to own this little rig was a retired machinist, so he may have had a good use for it?? It came with plenty of other usable goodies. Hold down kit, 6.5" rotarty table, end mills, boaring bar, fly cutter, r8 collets, 2 vices, a few drill bits, and a light. This RF 20 is silky smooth, with an upgrades 2hp motor. And now I'm shopping for a CNC kit, 4 axis, gotta get the rotary table with a chuck.
    Feb 2006
    Good! Then give them to me! I'll use the he11 out of them! :-)
    Seriously, since you didn't even know what they are, you have no idea whether you'll use them or not. Few machinists would be without all of those things....
    Regards,
    Ray L.
    Registered arizonavideo's Avatar
    May 2008
    I give some cash for the C5 collet holders. I have a C5 set and could use them.
    Send me a PM.
    br1
    br1 is offline
    Oct 2006
    Do those "2-4-6" bolcks actually measure 2 inch by 4 inch by 6 inch? that is a find in itself. Those can be very handy. Never heard of a RF20 Sears mill, Is it something old, just courious.
    Oct 2009
    Quote Originally Posted by br1 View Post
    Might be wrong othe sears thing. It's a Fairbanks Ward RF (rong-fu) 20. The year on the motor says 1983. I haven't found any info on the web, none worth a darn any way.But I did find a manual for the rf20, on this site.
    2-4-6?? beats me, thats what they call them. http://www.grizzly.com/products/2-4-6-Blocks/G5642
    also have a set of these. http://www.grizzly.com/products/Fly-...-2-Shank/G5716
    and another drilling item. It has a 3/16 drill bit and an indexing bar off to one side that holds a cutting bit, like one that you would find on a lathe. I guess that would be used for making holes.
    Oct 2009
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Ha, plenty of interest tells me I have something cool. Collet closers are not cheap, from what I can tell. And it makes a hell of a paper weight, for now.
  • Page 1 of 2 12 LastLast
