Results 1 to 10 of 10
Thread: iGaging Scales "Mod"
    Jun 2011
    Lightbulb iGaging Scales "Mod"
    After spending much time on different sites, I decided to make this one my home for discussing machining topics. Hope that is good with "y'all"
    So I decided to put some DRO on my SX2 after loosing track of where I was and taking off 1/16" too much.
    Eventually, I will CNC this thing, so I wanted to cheap out. I bought a set of iGaging scales and took one apart. Figured I'd show some pics of the guts:
    One you remove the hot glue and the mini-USB connector, you'll have access to the four white screws that hold down the scale, and the four black screws that hold down the PCB. I found that if you tighten the black screws too much, you increase drag as the encoder slides along the scale. I did not find the same to be true for the white screws. Of course, I didn't crank on either of them.
    Now, in this next pic, you can see that as the scales changes direction, the scale contact is pushed in the direction that the scale is moving. There's about 3/8" of play. I'm not an expert on this type of scale technology, but my instincts tell me that play is not a good thing. The more consistent everything is between capacitance readings, the more precise the readings will be. So I decided to add a dab of hot glue on one side.
    I thought it couldn't hurt. Everything seems to be working fine. The PCB does a good job of holding everything steady, so this might not improve anything. But if you look closely at the PCB where it touches the scale contact, you can see sign of rubbing, which indicates slight play. These are brand new as well, so only 5 minutes or so worth of use to test it out.
    Banned
    Aug 2011
    Ill be checking mine out, they will be installed this weekend. Thanks
    Feb 2006
    That contact moving on direction changes will make absolutely no difference....
    Jun 2011
    Quote Originally Posted by HimyKabibble View Post
    I'm listening. Would you kindly describe the circuit?
    You're absolutely right. Electrons will flood the entire bar.
    Feb 2006
    Quote Originally Posted by FunkedOut View Post
    The only purpose of that contact is to provide a ground path to the bar, which acts as a shield for the PCB under the legend strip on the bar that is the actual sensing element. The contact sliding within the housing will not prevent it from doing that, and will have zero effect on operation.
    Regards,
    Ray L.
    Jun 2011
    so, would i be alright to cut the length of the bar?
    how about drilling a hole in the end of the bar for mounting without the brackets?
    Mar 2010
    I have cut 2 of the bars down and it has not affected operation. I have not tried to drill a hole in them yet.
    Feb 2006
    Cutting the bar is fine. If you drill it, be sure you slightly chamfer the hole on the front side, to make sure the traces on the PCB don't end up shorted. It won't hurt anything if they're shorted, but the scale won't read correctly.
    Regards,
    Ray L.
    Jun 2011
    thanks for the help
    Banned
    Aug 2011
    I have mine mounted and haven't seen any issues with them, after re-reading your post and looking at the pictures, I agree it's not needed. Hope you got them to work ok.
    1. Need Help!- iGAGING DRO SCALES.MOUNTING G0704
      By macatoms in forum Benchtop Machines
      Last Post: 02-28-2013, 12:02 PM
    2. Replies: 12
      Last Post: 06-27-2012, 07:30 AM
    3. Need Help!- "motor steps per resolution" and "driver microstepping" settings
      By margni74 in forum LinuxCNC (formerly EMC2)
      Last Post: 10-24-2009, 03:33 AM
    4. "J" head type "millport"(tiwan,1980) clutch
      By marksbug in forum Bridgeport and Hardinge Mills
      Last Post: 08-17-2009, 11:48 AM
    5. BattleAxe "aka" Ball and Chain "aka" the wife.
      By ZipSnipe in forum CNCzone Club House
      Last Post: 05-18-2008, 10:53 AM
