What materials will you be cutting? How thick? How long do you want to wait for a part to finish? Do you have any machining experience? Manual or Cnc? Personally I wouldnt go the Sherline or Taig route. Both are operable machines with a lot of support, parts and satisfied customers. Having your round column mill could be converted (x & Y would be easy) Z would be a little more difficult but easily doable. There are some inherent issues with the round column but there are pros and cons to every set up. Go for as much travel and rigidity as you can start with or afford. Forget the manual use of a cnc machine. It simply is not necessary. It is a fear all of us had and most all of us are quite happy without it. You will be able to manipulate your machine accurately via a keyboard, an mpg or a simple game controller. Once you get a uniform cnc pass via MDI or a complete gcode you really wont want to use manual again. IMO
LinkBack URL
About LinkBacks
