Results 1 to 9 of 9
Thread: square pockets and holes?
    Jul 2011
    I know this is probably a stupid question (round end mills and sharp inside corners)
    can these mills cut sharp corner (L) pockets and holes in sheet-metal for computer case panels or console panels or am i going to have to contract a plasma cutter?
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    There is no way for a endmill to cut a square inside corner.... the corner will have a radius equal to the size of endmill. You will need a jig saw or plasma to do what you want.
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    Jul 2005
    Square cornered pockets are approaching impossible.
    Square holes are feasible: Google "rotary broaching"
    Aug 2011
    Bulgaria
    Since we're talking about sheet metal here I'd avoid any mills or lathes for it, depending on the type of pocket you want made (the size of it) I'd recommend either a punch press or a laser to do those for you, the punch press is significantly cheaper to use for mass production, but the laser will do a better job at shaping the pockets at a significantly higher cost, its your choice to decide which one you preffer.
    May 2010
    wire edm.....lol, just to throw another, rather rediculous option at ya :P
    Nov 2009
    For one offs you could always just clean the corners up with a file.
    Oct 2008
    I've done some pretty good triangles before but it wasn't on purpose. Loose gibs and a way too high feedrate and it had lots of sharp corners
    Rev
    SX-3 Mill, 10x22 Lathe, RF-45 Mill, GH-1340 Enco Lathe
    Dec 2004
    You can relieve the corners with an end mill, this is done all the time with square pockets in thicker material. If this is in sheet metal it will require solid clamping to avoid vibrating the sheet metal. The number, size, and proportions of the square cut outs may affect whether this is a good choice or not. For prototype work a simple die/punch like a shim punch is often employed. If you're going to run production numbers then a punch press might be a better route. You haven't provided enough information to give you a better answer.
    Jul 2011
    thanks for your replies guys...question pretty much answered
    Richard
    1. square holes
      By JPMach in forum General Metalwork Discussion
      Last Post: 11-12-2011, 11:29 AM
    2. 4 holes in Square Column looks squeeshed.
      By boana in forum Rhino 3D
      Last Post: 03-07-2011, 10:10 PM
    3. Newbie- Square hole in square tube
      By bubblybill in forum General Metalwork Discussion
      Last Post: 09-20-2009, 11:18 PM
    4. Drilling square holes ??
      By FPV_GTp in forum General Metalwork Discussion
      Last Post: 08-28-2009, 03:38 AM
    5. square holes - reciprocating file??
      By andy_ck87028 in forum Mechanical Calculations/Engineering Design
      Last Post: 10-21-2005, 09:44 AM
