Results 1 to 4 of 4
Thread: Milling Smooth Bottomed Hole?
    Registered Otokoyama's Avatar
    Oct 2004
    U.S.A.
    Does anyone know a good technique for milling a hole with an exceptionally smooth, square bottom about .5" deep? The finish on the sides of the hole don't really matter.
    Jul 2004
    I've just used a G02 to mill pockets for bearings & such. Make sure you are using a center cutting endmill. Helps if you can ramp into your cut.
    Moderator HuFlungDung's Avatar
    Mar 2003
    An Iscar Helimill does a really fine job of finishing a blind hole, with a light depth of cut. Your machine and work has to be really solid, of course.
    Oct 2004
    U.S.A.
    Thanks!
