Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: X2/SX2 CNC conversion without ball screws?
    Apr 2011
    Anyone still do this? All the conversions I see posted include a CNCfusion kit or some DIY ball screws.
    Nov 2010
    Charlotte NC USA
    It's possible, sure. Mach 3 will compensate for the backlash, but it's best to get it as low as possible first. Even with ballscrews, I have .003"-.008" backlash in my axes....most of that, I believe, is from the lovejoy couplers. If you put an anti-backlash nut setup on the stock lead screw and use zero-backlash couplers, you could probably reduce the slop to an acceptable level.
    For me, the mounts included with the fusion kit sealed the deal. Very nice fit/finish. The ballscrews themselves aren't too terribly expensive if you turn the ends yourself. You can always make your own mounts for now and upgrade to ballscrews later.
    Apr 2011
    Quote Originally Posted by rewster View Post
    I was thinking it would be more cost effective to buy a lathe with the money saved from not buying the fusion kit.
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    Bmr4life,
    When I converted my X2 I used the stock screws and have never converted them to ball screws. There will be backlash and mach can compensate but you want to try and get it as low as possible. You can split the nuts halfway through and add a setscrew to help take up some of the backlash. Also if you are looking to save some money look at the Probotix kits 3-Axis CNC Stepper Motor Driver Kits. I used the probotix and have had 0 issues in the past 2 years.
    You can see here on another uses build what I am talking about with the nut.
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    Dec 2009
    Sure you can. I'm running my machine on stock screws right now and it works pretty darn well. Problem for me is that on the X axis since it is so long the backlash at the center is different than at the edges so I had to error map the screw to get decent accuracy outside the center zone. If I adjust it out to low values in the middle it will bind at the edges.
    I'll be going to ball screws soon because the higher friction at the edges of travel has meant that I have to run pretty slow to insure I don't stall at the ends of the tables and I have to avoid any cutting outside the center 13" of travel of the 17" I have.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    Apr 2011
    Nice, thanks for the replies
    Eartaker, which Probotix set is sufficient?
    Jul 2009
    USA, Tacoma, WA
    I went with the Monster kit with the 40v power supply, but allot of people are getting away with lower torque motors. 3-Axis Monster Stepper Motor Driver Kit - 3-Axis Monster Stepper Motor Driver Kit
    Jermie
    Apr 2011
    Quote Originally Posted by eartaker View Post
    Thanks, but how much less is that? $475 with the 40v PS. Aren't G540 kits around $600 with ~400oz motors?
    Gold Member hoss2006's Avatar
    Apr 2006
    A 3 axis g540 kit is only $455 at keling, the best performance for the money.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jul 2009
    USA, Tacoma, WA
    All depends on what you want. I have never used the g540 but it gets good reviews.
    Jermie
    Apr 2011
    Quote Originally Posted by hoss2006 View Post
    Hoss
    What's the difference between KL23H284-35-4B & KL23H2100-35-4B motors?
    I see you say to get the KL23H2100-35-4B on your website. You also call out the 4 axis kit, but I assume I could just get a 3 axis and add a 4th motor later if I ever wanted to.
    Apr 2006
    Not much difference but the KL23H2100-35-4B (381) has a lower inductance which
    would give a little better top speed, if sold out the 387's are perfectly fine too.
    Hoss
  • Page 1 of 2 12 LastLast
    1. Can these ball screws be used for 9x42 bridgeport conversion
      By ichudov in forum CNCzone Club House
      Last Post: 12-23-2008, 07:26 PM
    2. ball screws
      By chevdrgtrk in forum Bridgeport and Hardinge Mills
      Last Post: 03-30-2008, 12:37 PM
    3. ball screws
      By matt in forum DIY CNC Router Table Machines
      Last Post: 05-21-2007, 02:36 PM
    4. Ball screws, Acme screws, threaded rod
      By DJ Morrow in forum DIY CNC Router Table Machines
      Last Post: 03-22-2007, 01:39 PM
    5. Ball screws
      By BluesMagoos in forum General Metal Working Machines
      Last Post: 01-08-2005, 01:09 PM
