Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Fried C11T board??
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    Fried C11T board??
    Thought I would start a new thread for this since the topic is different.
    While building my power supply everything was going fine until I guess I shorted something out on my low voltage side and didn't know it. I ended up applying 20V to the C11 and now when apply 5V I get 4 LEDS that light but and one of the chips near the parallel port just heats up. Anyone thing getting a replacement set of Buffers and optoisolators world get the board running again?
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    May 2007
    Where on the board did you apply the 20V, and why?
    Jul 2009
    USA, Tacoma, WA
    where you power the board. My power supply I built died when I connected it to the board because I guess my chips weren't rated for 2A. It cause a short and supplied the 20V to the board that I was powered the chip with.
    Jermie
    Feb 2010
    I did something similar with my C11 when I got it running. I was wiring everything up on a bench for testing, and then moved everything to an enclosure. In the process of moving everything to the enclosure, I swapped some wires on the power input pins and fried the board.
    I did end up replacing the opto-isolators, and the board works great now. I picked mine up at a local electronics shop, just because I didn't want to wait for the mail. I think CNC4PC's price for an entire set of replacements is hard to beat, so I would definitely say its worth it.
    Eric
    Jul 2009
    USA, Tacoma, WA
    Eric,
    Thanks I didn't know if this would get it going or not. I will place the order now.
    Jermie
    Jul 2009
    USA, Tacoma, WA
    Talked to Art and he said I may have more issues then the chips will fix but im going to try and hope for the best. He suggested to just replace the board. Also went ahead and ordered the MPG2 - Pendant.
    Jermie
    Jul 2009
    USA, Tacoma, WA
    Any thoughts on the PMDX-126 with PMDX-107 VS the C11T? If i cant get the C11 going I will not replace it with another C11.
    Jermie
    Jul 2009
    USA, Tacoma, WA
    Well the new chips did nothing so if anyone needs them I have a new set of them I can send to anyone if ever needed. I REALLY dont want to buy another C11T board. I have been looking at the PMDX-126 with the PMDX-107 for spindle control. This board seems like it will allow for a lot of expansion in the future if needed.
    Anyone use this setup? Any thoughts are greatly appreciated.
    Jermie
    May 2007
    Why do you not want another C11? I've had good luck with mine and wouldn't hesitate to buy another or anything else of the sort from Art.
    Jul 2009
    USA, Tacoma, WA
    Well it seems also of the people are having issues with the new revision. Also I just got my MPG4 and it is not working right.... it wont recognize every detent and makes the axis go crazy. Every switch and button works though.
    Jermie
    Oct 2008
    Much nicer and professional looking setup in my opinion. I'm having second thoughts on the C11T as well although I haven't had time to test the "revised" firmware. It was all laid out out my work bench and wired up for a couple weeks waiting on the new chip and I finally had to put it all away for another project. When I get time I'll try it and see how it does and report back.
    Quote Originally Posted by eartaker View Post
    Rev
    SX-3 Mill, 10x22 Lathe, RF-45 Mill, GH-1340 Enco Lathe
    Jul 2009
    USA, Tacoma, WA
    Richard,
    They do seem to look more professional. I also like how you can directly interface the smooth stepper board with them as well as other boards. I am going to call both Art from CNC4PC and Steve from PMDX tomorrow and make a decision. I am leaning more toward the PMDX right now though. I mainly want to find out whats going on with this MPG, I think it is broke and was when it was shipped. Kind of odd how every button and switch will interface with Mach3 but the MPG will not act as it should. It detects about ever 4-6 detents and only runs in one direction, also if I rotate it faster than 4 detents per second it wont move the axis at all. I have had a bad week with all things electronic.
    Jermie
  • Page 1 of 2 12 LastLast
    1. I Think i fried something (Help please)
      By Rainman229 in forum Syil Products
      Last Post: 03-22-2010, 12:00 PM
    2. fried
      By corrie in forum General Electronics Discussion
      Last Post: 03-23-2008, 11:29 PM
    3. Fried X2 Board
      By dang in forum Benchtop Machines
      Last Post: 09-21-2007, 08:48 PM
    4. Have I fried my board?
      By Coolcuttings in forum Xylotex
      Last Post: 12-28-2006, 05:28 AM
    5. Is my 320 fried?
      By DAB_Design in forum Gecko Drives
      Last Post: 11-13-2006, 12:41 PM
