If you're thinking this is a problem with Mach3, think again. Your machine is losing steps, which means the drives are either under-designed, or you're pushing it too hard.
Regards,
Ray L.
hi. i am using mach 3 and all wizzards work fine.
when i run large programs (1000 lines plus) the machine drifts out of algnment by about 5mm. this is progressive as the program runs. can anyone give me any idea's please.
Andy
Regards,
Ray L.
i have run at very slow speeds but still get drift. it always seems to be exacly
in 5mm steps not 5.1 or 5.4 etc... this is why i think it is software not machanical. all axis are very smooth and my drivers are high quality vexta units. paid £250 each. these are matched with the correct motors as they came as a kit.
Andy..
I had a problem on my x2 a while back where it would routinely lose .1". I changed the motor speeds,etc but I think what may have fixed it was setting the kernel speed down to 25000.
i had this issue a few years back when the G540`s first came out. I was able to solve it by setting the sherline 1/2 Pulse mode.
my 3d tool paths would come out very distorted the longer the machine ran. maybe its worth a try on yours.
I could be misunderstanding your problem, but couldn't the culprit be incorrect backlash settings, especially noticeable on asymmetrical parts?
thanks for the comments. will give it a go the week end. will let you know how i get on.
Andy..
