Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: Shop Press? How does it do that?!
    Registered nateman_doo's Avatar
    Jun 2010
    How do shop presses work? Lets say for instance, I wanted to press fit a sweat cap over a pipe? how would it clamp and put pressure 360° around it?
    (yes I know it would be soldered/brazed/sweated-Just looking for theory)
    Nov 2009
    washington state usa
    Well, if we are talking about copper here ,caps would be slip fit. So, why would you need a shop press? The caps or couplers or fittings should just slide on.
    I only really use mine for separating bearing assemblies, swedging, flairing, seating bearings, broaching etc...
    Is there more to the question?
    JTCUSTOMS
    Jun 2010
    I have a section of 2" solid rod of copper, that I want to press into a 2" ID copper pipe. I don't wish to braze it because that thing takes lots of heat (and I only have a single propane torch). It has to clamp the pipe and be watertight.
    I am not looking for alternate means, just looking into the process of how a shop press can work to seal the "plug" into the pipe.
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    nateman_doo,
    A press simply uses a great amount of pressure to push 2 pieces together. The seal will be determined by how much pressure is needed to force the 2 parts together and how round they both are. If you rod is 2" in dia and your pipe is 2" OD this will not work. but if the pipe is 2"ID you should have a firm fit.
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    pp7
    pp7 is offline
    Sep 2010
    Quote Originally Posted by nateman_doo View Post
    I apologize for offering "alternative means."
    If you want them to seal tightly, I would suggest another way. You can put the rod on a lathe and trim to exactly 2.000 inch. Put the pipe on a lathe and bore the inner diameter to 1.995 inch. This will create 5 thousandths overlap. Place the rod in a freezer for 10 minutes. Place the pipe in an oven to 300 degrees for a few minutes. The difference in temperature will create about 6 to 7 thousandths difference. Fit the pieces QUICKLY together, before the temperatures equalize.
    Feb 2011
    Sounds like you may be looking for an interference fit:
    Here's some basic info:
    http://www.engineersedge.com/bearing..._press_fit.htm
    There are other sites for dimensions, using different materials, etc.>
    Jun 2010
    Quote Originally Posted by pp7 View Post
    No need to apologize. That sounds interesting, but I don't think I could get the tolerances that close on my Harbor Freight 7x10 lathe. I was thinking of making a steel jig like so:
    And making the hole just a thousandth smaller then 2" so that when it clamps all the way around it should compress the pipe on the solid core. At least thats my theory.
    Aug 2008
    It looks like you are wanting to CRIMP the pipe, which means you presently have a slip fit.
    To create a press fit, you would force the rod into the pipe if the inside dia. of the pipe is undersize. To press it in dry would cause galling, and would not seal.
    To CRIMP the pipe with your steel jig you won't get a watertight seal either, unless you are able to insert an o-ring, silicone, or other collapsable membrane first, and just use your crimp as a lock so that pressure cannot blow them apart.
    Make sure that your jig fits close around your pipe, and create a lobe on each half that can bite into the softer copper. It will work even better if you grind or machine small cavities on the rod at the same position. Just press down with your crimper, rotate it 90 deg. and repeat.
    You didn't mention the length of the fit. If you have room, you can repeat the process farther down the pipe, but like I said, the crushing force will not give a water tight seal if there is any pressure what so ever.
    Good Luck!
    Jun 2010
    Can you elaborate a bit more? There will be nothing but atmospheric pressure. maybe the volume of a cup of water at the most behind the seal.
    I saw this picture and I was curious how the process worked:
    Tinkerer
    Nov 2009
    You should be able to get the tolerances to achieve a watertight seal easily with your lathe. Put 1 in the oven and the other in the freezer, they will go together and once back to ambient temperature, you wont get them apart nor will they leak.
    Click image for larger version.
    Jun 2010
    nothing will crack when exposing cold metal to very hot metal?
    pp7
    pp7 is offline
    Sep 2010
    I placed (frozen) bearing races my my custom wheel hub (heated to boiling temp) recently. Nothing cracked. You only get one try, though. Once the temperatures equalize, the parts are mated permanently.
  • Page 1 of 3 123 LastLast
    1. Need Help!- Hydraulic Shop Press
      By diyengineer in forum Want To Buy...Need help!
      Last Post: 07-13-2010, 07:05 PM
    2. Need Help!- Selecting Press for home shop press brake
      By tikka308 in forum Bending, Forging,Extrusion...
      Last Post: 12-28-2009, 11:51 PM
    3. shop press brake
      By nc9933 in forum Bending, Forging,Extrusion...
      Last Post: 02-07-2009, 09:58 AM
    4. Help - H Frame Shop Press V Die
      By tikka308 in forum General Metal Working Machines
      Last Post: 09-17-2008, 09:47 AM
    5. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
      By dsmdude in forum Bending, Forging,Extrusion...
      Last Post: 04-13-2007, 05:01 PM
