Results 1 to 6 of 6
Thread: New Grizzly G0619
    Jan 2011
    New Grizzly G0619
    Hey guys,
    I think I have read so much I am going blind!! So much good information here from everyone!!!
    Anyway, I have this new G0619 mill on the way from Grizzly and I want to CNC it right away. I need to purchase the electronics and the CNC Fusion kit. I am looking at the following and would appreciate any advice.
    From Keling:
    G540 4 axis package (one G540 + oneNEMA 34 KL34H295-43-8B, 906
    oz-in +Three NEMA 23 KL23H2100-35-4B (1/4” Dual shaft with a
    flat) 381 oz-in + one KL-600-48 48V/12.5A 115V /230V
    power supply): $630.95
    I know Keling makes a 3 axis kit just for the X3 but this kit seems more substantial, and I want the 4th axis.
    From CNC Fusion:
    Kit #4 or Deluxe. (If I can get away with kit #4 it would be nice to save the coin).
    My questions:
    1. Will it work with these components?
    2. How well will it work (subjective I know....)?
    3. Other recommendations?
    I want to use the mill mostly for gun work (milling receivers such as AR15, 1911), boat stuff, and anything my wife makes me do for her in trade!
    I have a Shark Pro CNC which uses NCPOD, NEMA 23 3 axis, Vectric software 3D Cut, Vcarve Pro v6, and Photo Vcarve. I figured I can reuse the Vectric software. So I am familiar with CNC, but this will be my first mill. So I will be a garage NOOB mill guy.
    I will probably run EMC2 or Mach 3 ( Any recommendations appreciated ).
    Thanks everyone!
    Jimmy
    Nov 2009
    washington state usa
    Sounds like you are off to a good start!!!
    I personally would spend the extra coin on the deluxe kit, which I did.
    make sure you get the CR option with your kit from cncfusion.
    I have had mine converted for a while now and am loving every minute of it, if I can affer a little advice it would be to spend some time on the ways and gibs especially the Z with a little work these can be very capable little mills
    good luck!
    JTCUSTOMS
    Apr 2011
    You got your mill yet? I'm curious how much the heaviest part weighs.
    Registered Crevice Reamer's Avatar
    Mar 2008
    Quote Originally Posted by Bmr4life View Post
    The SX3 breaks down into 5 main parts:
    1: Head. (Still connected to electronics tower}
    2: Column
    3: Saddle
    4:table
    5: Base.
    The head/motor weighs the most. About 90 pounds.
    I took mine apart, built the stand and then assembled it onto the stand: Base, Column, Saddle, Table. Crank down the head mount, put blocks on the table, Set the head on the blocks and install head to rotary mount. Quite manageble by one person.
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Apr 2011
    Oh, that's definitely not that bad.
    Mar 2008
    Teardown pics:
    Page 28
    CR.
    1. Need Help!- Grizzly G0619 Sx3 spindle bearings replacement
      By flashbang in forum Benchtop Machines
      Last Post: 03-20-2013, 12:19 PM
    2. New Grizzly G0619 Arrives
      By magma-joe in forum Benchtop Machines
      Last Post: 07-28-2010, 09:37 AM
    3. Need Help!- GRIZZLY G0619 IN THE ALBQUERQUE AREA?
      By ricksigler in forum Want To Buy...Need help!
      Last Post: 06-22-2009, 07:02 PM
    4. Seig SX3 = Grizzly G0619 = Shop Fox M1111
      By blacksmith99 in forum Benchtop Machines
      Last Post: 01-03-2008, 06:46 PM
    5. Any opinions on the Grizzly g4016 lathe or other Grizzly lathes?
      By DublD in forum General Metal Working Machines
      Last Post: 11-26-2006, 01:23 PM
