good luck, I work on the 10 times rule with electronics and enclosures. it will take you ten times longer than you expect it to.
Building an enclosure right this moment , started on it at 2:00 Sat. Afternoon.
Should finish it by noon Sunday. All from home depot and ace hardware. 32 wide 30 deep 30 tall
Total build around $130.00
I'll post pics. Later Peace
Almost finished it today, drank some beer and lost some motivation.
Then the Pro Bowl came on. I could have finished it then I got stuck on how to do the front doors. Can't slide up cause the pitch of my roof , A-frame cabin.
I will get some hinges tomorrow an make split doors opening to each side.
Enclosure would not fit the door of my hobby room , .53 too wide.
Remove room door and went in. That was a close shave
Remember the 6 P's
Proper - Planning - Prevents - Piss - Poor - Performance
Built ventilation system for enclosure today. 6" flex pipe and 4"dry vent tubing with a 5" component fan 85 cfm seems to plenty of ventilation. Both pipe outside of the house , taking a cut and running wide open the enclosure only emits 18 decibels and a inside temp. Of 64 degrees . In the summer I'll hook the intake to the air conditioning vent.
THIS THREAD IS WORTHLESS WITHOUT PICS!!!!!!!!!!
Peace
Pete
