swivel Vise, probably a Shars or Enco.
You cant rotate past about 50 degrees without removing the mounting bolts supplied with the vise.
I just wanted to check before I cut the bolts off shorter, am I missing something?
Thank you.
You should be using T-nuts, with the bolts going in from the top, then the bolts should not interfere.
Regards,
Ray L.
