Results 1 to 6 of 6
Thread: Flycutter for Proxxon MF70
    Aug 2009
    Does anyone know where i could find a fly cutter to suit the MF70?
    i'm still using the standard collet set on a stock motor. Most of the fly cutters i'm seeing use 3/8 or 10MM shank which is way to big for the MF70. Hope to get some good leads from the more experienced users!
    Thanks,
    Dash
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    Fly cutters are not normally used on the smaller mills like the X1 and the MF70. You can use some small ones on the X2 but it is still a flaky process. What is the maximum shank size you can use? and do you have a R8 spindle?
    Also if I am not mistaking the MF70's lowest RPM is 5000, is that correct? if so you do not want a fly cutter spinning at that speed.
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    Nov 2008
    Austria
    Hi
    Dash: Fly cutters are very easy to build - if you have acces to metal lathe. Without lathe... sadly, i dont know anybody that sells so small flycutters (market niche?).
    Jermie: I have Proxxon's Mill/drill system BFW 40/E, it's bigger than MF70 but smaller than X1 - and most of the milling operations is done with self built fly cutter. Mostly because it's so cheap and easy to resharpen. On the other hand cut diameter of my "big" fly cutter is 30mm As for MF70 - 10-12mm in aluminum should be possible.
    Gregor
    Aug 2009
    thanks for the replies gents.
    Yep the minimum speed is 5K rpm on the stock setup. i'm not sure what the current spindle is, the largest collet size is 3.2mm which is basically dremel tool size. there is a mod i can get to add ER11 compatibility by changing the spindle bearing and then adding a planetary gear system to reduce the speed/add torque. However i think the biggest shaft size i can use is 8MM with that setup, which is still a little shy of 10MM or 3/8" (~9.5mm). Though, that might pave a better foundation for a custom flycutter.
    unfortunately no lathe in my little workshop yet! looking at getting an c2 or c3 at some point in the future. but i'm not sure i'd trust using a 3.2mm shaft to support it though logically it sounds possible. To my understanding a flycutter uses comparatively less force in its operation than most would think. If 5K RPM is definately too high to risk then i suppose it wouldnt be worthwhile investigating this further.
    I was hoping there might have already been some off the shelf solutions to this, as the MF70 has quite a following.
    Gold Member widgitmaster's Avatar
    Jun 2005
    At 5000 RPM, it better be perfectly balanced, or your spindle motor will vibrate in to a pile of projectiles!
    Dremel sells rotary files around 1/4" dia, and that must be held rally short!
    Widgit
    Jun 2005
    Flycutter for the Taig Mill
    Maybe you can get a friend to do the turning for you. hope this helps
    cheers,
    tim
    1. New Machine Build- Proxxon MF70
      By itsStorm in forum Want To Buy...Need help!
      Last Post: 06-05-2010, 03:11 PM
    2. Proxxon MF70
      By iceblu3710 in forum Benchtop Machines
      Last Post: 06-18-2008, 02:18 AM
    3. Need Help!- PROXXON MF70
      By GeoCasa in forum Benchtop Machines
      Last Post: 03-11-2008, 01:32 PM
    4. Problem- PROXXON MF70
      By GeoCasa in forum General Metalwork Discussion
      Last Post: 03-08-2008, 08:22 AM
    5. proxxon mf70 cnc
      By fidia in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-28-2007, 12:44 PM
