Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: Total newb, Looking to mill copper.
    Oct 2010
    First I would like to say, I'm sorry mods lol, I seem to be posting stuff in the wrong place. I think I found my posts home in this one... I hope.
    Hi guys. I just spent hours reading a wood working thread lol. I'm looking at making some heatsinks. I really hope i'm in the right forum. The parts would look something like this.
    The biggest one would be about 4in wide and 12 inch long. So i'm guessing the X3 conversion right? But I can't seem to find to many detailed threads on converting Manual mills to CNC mills. I'm pretty new so I would need a thread with some hand holding :-).
    Thanks for the help.
    Oct 2010
    So i'm looking through the forum and it seems like Grizzly G0704 is better?
    Gold Member hoss2006's Avatar
    Apr 2006
    Have you looked at a Taig?
    You'll need higher rpm for milling copper, the Taig spindle can spin 4-5 times faster
    than the larger benchtop mills out of the box.
    It's work area, 6x12 should just do you and you can get a cnced version for less than 2K.
    Look on the taig forum for Deepgroove.
    Taig Mills & Lathes - CNCzone.com-The Largest Machinist Community on the net!
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Oct 2010
    Aw, I wanted to build it :-(.
    Apr 2006
    You have to assemble it so it's almost like building it.
    Hoss
    Oct 2010
    Quote Originally Posted by hoss2006 View Post
    Hoss
    LoL. At least people on this forum are nice. I belong to some computer nerd forums with post nazi's that will breath fire down your neck for posting in the wrong subform. I always thought copper was a soft easy metal to cut, seems I have a lot to learn.
    Apr 2006
    Copper is pretty soft, real gummy,
    Softer material like aluminum and plastics require higher rpm,
    harder materials like steel need lower rpms.
    Copper is in the middle ground as you can see in this chart.
    http://www.endmill.com/pages/trainin...nd%20Mills.pdf
    The larger benchtop mills peak at about 2000-2500 rpm while the Taig can reach 10,000.
    Doesn't mean you can't run copper on the bigger machines, just have to feed slower, just that the taig is better suited for it out of the box.
    Hoss
    Sep 2010
    High RPM'S and low feeds. Copper is really gummy and will load up your tooliing. If drilling use a mega pecking cycle.
    Sep 2010
    United Kingdom
    Hi M8
    I would give consideration into using copious amounts of coolant on that job as per a proper machining centre, will keep the job cool and flush the chippings from the internal finned component.
    Just my thoughts
    Good luck with the project
    Regards
    felderfan
    Oct 2010
    Hoss
    Well i'm going to go with the Taig. This is turning out to be my most expensive build yet heh (For a PC). But I figure I will be able to use it for awhile and maybe even sell a few blocks on the side. But this seems the only route to go. Hopefully by this time next year ill have a full LN2 bench rig :-)
    Thanks for the help HOSS.
    Mar 2010
    Cuttng Copper
    I have cut Copper with an O-Flute bit. This works at every spindle speed I have used as long as I match the Feed. Onsrud has them, but there are other manufactures as well. Dpending on the finish you require, I have had sucess using a chipload of .0042 for slotting with a 1/4" tool diameter.
    Jun 2005
    really? i would pay someone to build the copper blocks you want. your getting into an entire area of expertise. copper is not that easy to machine at the home level, not to mention, you not only need a machine, but you need software, and then you need tooling, and then what happens when you find out the parts you made aren't flat and leak water all over your electrical parts?
    there are tons of machines available used that people thought they can do the job your asking. they spent about $5000 to build a machine and tool it up only to find out that the part they want to make takes forever and it breaks a bunch of tooling along the way and then they got bored and forget all about it and now want to sell a machine that they have 5k into thats worth about $1000.
    only start this path if your really serious about making what you want, other wise even if your parts are $250 ea, its still cheaper than 5k+ for a machine and some software that may or maynot work like you want it.
  • Page 1 of 2 12 LastLast
    1. Replies: 3
      Last Post: 10-01-2011, 07:59 PM
    2. Total newb, Looking to mill copper.
      By YellowGT0 in forum LittleMachineShop CNC Machines
      Last Post: 10-29-2010, 12:47 PM
    3. Total Newb question
      By wilson248 in forum General Metal Working Machines
      Last Post: 03-23-2010, 10:34 PM
    4. Total newb with 10k
      By dandy7200 in forum Commercial CNC Wood Routers
      Last Post: 09-07-2007, 11:32 AM
    5. So- total newb here, trying to decide if a tumbler is for me or not- to polish...
      By peter.blais in forum Mass finishing equipment/media/stratigies
      Last Post: 03-25-2007, 02:09 PM
