Results 1 to 6 of 6
Thread: Anyone else have problems with wd-40 cans clogging up?
    Mar 2009
    I'm having problems with wd-40 cans that are nowhere near empty clogging up on me. Does this happen to everyone else too? Seams like the colder it is the more likely it is to happen too. What causes this and can anything be done about it?
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    Slashmaster,
    There is a red dot on the edge of the container. If the nozzle is not pointed towards the dot, CO2 may escape without drawing the liquid.
    Unfortunately the CO2 can be exhausted before consuming all the liquid hence a 1/4 full can that you can't use.
    Purchase the non-aerosol product instead.
    WD-40 Trigger Pro | Non Aerosol Multipurpose Lubricant
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2009
    You could also buy it by the gallon and put it in your own squirt bottle for about a third the cost per ounce. No aerosol to leak out or clogs.....
    Registered kanton's Avatar
    Jun 2003
    Jeff,
    I have the WD-40 Smart Straw. Does it have this problem? If so where is the red dot on the edge of the container or other indicator?
    Registered mwood3's Avatar
    Jun 2008
    Quote Originally Posted by kanton View Post
    Jeff,
    Ive about used a whole can of wd40 with smart straw...no problem so far
    http://www.g0704.blogspot.com/
    Registered fretsman's Avatar
    Nov 2007
    Quote Originally Posted by mwood3 View Post
    Agreed, never lost a drop with the smart straw, but I have now recently switched over to the gallon container with the spray bottle (wish they made one with a straw!).
    Just makes "cents"
    Dave
    Dave->..
    1. Need Help!- HAAS Mini Mill 2nd Sump Keeps Clogging
      By robinasu in forum General Metal Working Machines
      Last Post: 11-25-2009, 02:47 PM
    2. Stop the Clogging ??
      By twocik in forum Benchtop Machines
      Last Post: 06-29-2007, 02:25 PM
    3. How to prevent cutting alumunium from clogging ?
      By Calico in forum General Metalwork Discussion
      Last Post: 11-09-2006, 02:34 AM
    4. log on problems
      By turmite in forum Forum Questions or Problems
      Last Post: 06-26-2006, 03:34 PM
    5. I need an oil dispensor. Hate little cans.
      By Swami in forum General Metalwork Discussion
      Last Post: 12-14-2004, 12:56 AM
