Results 1 to 2 of 2
Thread: DIY - CNC H/V Rotary Table
    *Registered User*
    Nov 2009
    U.S.
    I am in the process of making a new DIY-CNC H/V Rotary Table... I purchased a 30 to 1 worm gear reduction unit a few years ago for another application... That failed... So I'm going to see if i can make this work... It's just a standard 30 to 1 worm gear drive reduction unit... I'm going to machine a box to mount around it.. Then mount that box in a larger one... It will be aprox.. 8'' x 8'' x 4 1/2'' I"m designing it so it can accept a table up to or there about's.. 10''/12''.. I plan on machining a 1'' x 6'' MIC-6 table for it... Hopefully it will work out for this task... My primary reason for making one is to machine 1/4 scale V8 engine cam lobs... I'll have to figure how to make an attached/removable tail stock for it once i get it built... Shouldn't be hard to figure out..
    I've ordered all the aluminum and fasteners so hopefully I'll have it all and have it built in a week or soo...
    Here is a few pics of the cad rendering i did on it as well as a few of the reduction unit... I did manage to machine a hole threw the output shaft casing so i can mount a 1/2'' shaft... Whew... That was fun... Nothing like trying to drill a hole in hardened steel... A 3/16'' two flue end mill even had a challenge doing so..
    Stoney
    Attached Thumbnails Attached Thumbnails DIY - CNC H/V Rotary Table-diy_-_cnc_rotary_table.jpg   DIY - CNC H/V Rotary Table-diy_-_cnc_rotary_table.2.jpg   DIY - CNC H/V Rotary Table-diy_-_cnc_rotary_table.3.jpg   DIY - CNC H/V Rotary Table-dvc09732.jpg
    DIY - CNC H/V Rotary Table-dvc09736.jpg   DIY - CNC H/V Rotary Table-dvc09737.jpg   DIY - CNC H/V Rotary Table-diy-_6_cnc_rotary_table_001.jpg   DIY - CNC H/V Rotary Table-diy-_6_cnc_rotary_table_005.jpg
    DIY - CNC H/V Rotary Table-diy-_6_cnc_rotary_table_010.jpg
    *Registered User*
    Nov 2009
    U.S.
    Well the rotary table is now done... other than squaring up the enclosure a tad that is... There isn't alot of vertical height but there is plenty of horizontal height... I primarily built this to machine 1/4 scale engine parts... such as... Cam Shafts/Crank Shafts/Cutting ring grooves/cutting gears... I still need to machine a tail stock for it and machine a grinding attachment that will mount to the z axis...
    Gotta run
    Stoney
    Attached Thumbnails Attached Thumbnails DIY - CNC H/V Rotary Table-rotary_table_clamps_77_.jpg   DIY - CNC H/V Rotary Table-rotary_table_clamps_105_.jpg   DIY - CNC H/V Rotary Table-rotary_table_clamps_113_.jpg   DIY - CNC H/V Rotary Table-rotary_table_clamps_116_.jpg
    DIY - CNC H/V Rotary Table-rotary_table_clamps_117_.jpg   DIY - CNC H/V Rotary Table-rotary_table_clamps_123_.jpg
  1. rotary table
    By TarHeelTom in forum Bridgeport and Hardinge Mills
    Last Post: 08-17-2010, 12:16 PM
  2. Need Help!- CNC Rotary Table
    By KJ45 in forum General Metal Working Machines
    Last Post: 07-09-2010, 07:35 AM
  3. 60$ rotary table?
    By vacpress in forum General Metal Working Machines
    Last Post: 10-30-2007, 08:12 AM
  4. Rotary Table Req
    By h_2_o in forum General Metal Working Machines
    Last Post: 02-08-2005, 02:11 PM
