Results 1 to 7 of 7
Thread: Need suggestions for lighting for an X3.
    Mar 2009
    I've got an X3 that's in a dark corner of a basement, would like suggestions on how to light it. Not sure if I should find more lights for the ceiling, find some kind of snakelight to attach to the mill or find some small light I can mount under the head somehow (like some sewing machines). Any advice welcome.
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    If you go to Lowe's they sell some 36" shop florecent lights for like $9
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    Mar 2009
    Thanks, maybe I'll have a look next time I'm at Lowe's.
    Quote Originally Posted by eartaker View Post
    Registered Crevice Reamer's Avatar
    Mar 2008
    One of these, magnetically clamped to front of head and angled down, will light your table quite nicely:
    http://www.harborfreight.com/75-watt...ght-90766.html
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Registered neilw20's Avatar
    Jun 2007
    Stiff and brilliant.
    I attached my column to the wall for super stiffness and mounted a flouro on the stiffening strut.
    Plus added picture of part of the cabinet and the pump
    It is a BRICK WALL and until it shakes out the mortar, all will be well.
    30 times stiffer than it was when freestanding.
    I should do double brackets to stabilize the column sideways, but for the current job there is no twisting or sideways forces. Just 5KG down pressure with a worn out cutter, and 0.2KG with a new one.
    Note the long strut for extended Z travel all the way to the top of the column. About 385mm if I remember correctly.
    Attached Thumbnails Attached Thumbnails Need suggestions for lighting for an X3.-snc00411.jpg   Need suggestions for lighting for an X3.-snc00412.jpg   Need suggestions for lighting for an X3.-snc00416.jpg   Need suggestions for lighting for an X3.-snc00418.jpg
    Need suggestions for lighting for an X3.-sx3_wall01.jpg   Need suggestions for lighting for an X3.-snc00417.jpg   Need suggestions for lighting for an X3.-snc00419.jpg
    Last edited by neilw20; 09-25-2010 at 10:53 PM. Reason: Added text and CABINET picture.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Mar 2009
    Thanks Crevice Reamer, if I can't find something better I might go with that.
    Neil that's an interesting setup you have, is the mill still on a table? Is that a chimney or are all the walls brick? Looks like you must have used your X3 to drill into that wall.
    Feb 2006
    Ditto, I did EXACTLY that, and put the lights right over the mill (a little offset so the shadow of the head wasn't a problem). It works GREAT, and was super easy to install.
    -Jim
    1. Lighting Lithophanes
      By Tony Mac in forum PhotoVCarve
      Last Post: 11-01-2012, 07:39 AM
    2. Lithophane lighting
      By dmparrott in forum Vectric
      Last Post: 12-12-2008, 05:03 PM
    3. Need Help!- Lighting Zapped my RS-232 ports
      By M.E. in forum Fanuc
      Last Post: 10-22-2008, 01:32 PM
    4. Need Help!- Lighting problem VF-2 ss
      By nfs7713 in forum Haas Mills
      Last Post: 07-15-2008, 07:17 PM
    5. HAAS TM-1P Enclosure Lighting
      By HelicopterJohn in forum Haas Mills
      Last Post: 03-16-2008, 03:52 PM
