Results 1 to 3 of 3
Thread: CNC Fusion Kit #4 blocks Z-axis gib screws?
    Aug 2010
    Just finished installation of the CNC Fusion kit #4 on my X2. Finding that the z-axis mounts block the gib screws was unexpected. I read the instructions several times to be sure I wasn't installing the Z-axis incorrectly. Why would it be designed like this? Do people just remove the z-axis assembly to adjust the gibs? Are there any creative solutions? I found in a search that someone completely modified the z-axis to mount on the left side of the column, but it basically was turned to swiss cheese and required fabrication of a new bracket. For such an otherwise beautiful kit, I'm surprised it has this limitation.
    Advice appreciated...
    Jeff
    Registered Geekus's Avatar
    Apr 2010
    Hi Jeff, it may help if you added X2 to the title so folks with the same kit can easily find the thread. I was scratching my head for a minute since I have the X3 kit which has a different config for the z-axis.
    Aug 2010
    Quote Originally Posted by Geekus View Post
    Thanks Geekus... I can't seem to edit subject, so added X2 info to the original post.
  1. Need Help!- Fusion 640T SQT 200MSY Y-AXIS
    By Darchon in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-25-2009, 05:49 AM
  2. Mazak Variaxis 5-axis Gibbs CAM post 640 Fusion
    By btdmfg in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-18-2009, 11:19 AM
  3. How to set up two screws for my X axis
    By dan dimock in forum Linear and Rotary Motion
    Last Post: 12-16-2007, 09:06 PM
  4. X2 Z axis Spring and Fusion CNC Kit
    By Woodenspoke in forum Benchtop Machines
    Last Post: 02-05-2007, 07:01 PM
  5. end blocks for ball screws
    By senor J. in forum DIY CNC Router Table Machines
    Last Post: 02-26-2005, 03:05 AM
