Looking goood!!![]()
Hi Hoss,
Are you using the stock retaining method where the two bolts just put pressure against the ballnut mounting block?
Sean
Hi Hoss,
I looked at your dimensions for the X ballscrew mod. I have a G0704 from Grizzly but your measurements would result in interference on my machine. I think the difference may lie in the clearance / height of the space under the table where the X ballnut will reside. My height before milling a pocket for the ballnut is .800 , I am guessing your space may be closer to 1.00
or your Roton nut is smaller than my Thompson which is 1 in sq + the ball return on one side. I compared my measurements to yours and they were the same except that I had the pocket at .260 deep and a small slot to clear the ballscrew. If I remember correctly this gave around .050 clearance between the ballnut and the table. My table has a 3 stamped in the right end. Hope it helps.
Sean
P.S. would you mind to post the Gcode for the oil slots?
The Roton nuts are 1 inch square too, with the screws in the original end brackets, I still have about .050 under the nut in the pocket.
One of those variances folks will have to take into account between machines. It's not a critical bit of machining. Thanks for the info.
I can give the dxf for the oil grooves, same for all 4 flats on the saddle,
haven't done the z yet, it'll be different.
The Phase 2 prints are done.
http://www.g0704.com/phase_1_and_2_cnc.html
It's gonna be a good while before I move on to Phase 3,
I want to have some fun just using the mill under CNC for a while first.
Need to get it all plumbed for oil and then build a console, a Voight-Kampff machine clone perhaps.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
One more rapid test.
This isn't a baseline test with Mach 3 at the minimum 25000 Hz kernel speed like before.
I ran a cable to a good PC and jumped the kernel speed to 45000 Hz.
With the driver at 1/8 microstepping, 300 IPM came easy with the column still on the table.
Good enough for me.
Here are the electronics used.
570 oz/in Nema 23 Stepper motor, Keling KL6050 driver, 48V.
http://www.g0704.com/G0704_electronics.html
Motor tuning settings - Steps Per 8000, Vel. 300, Accel. 60.
Also shows the motor on the left side of the table as an option.
Hoss
[nomedia="http://www.youtube.com/watch?v=3639EIzUc6w"]YouTube - G0704 Max Realistic Rapid Speed[/nomedia]
Hoss,
do your phase2 plans include information on AC bearings for the ballscrews, where to buy them, and prints for bearing blocks and preloading them properly?
If so, how much are the bearings that you're recommending?
Ian
Excellent. I placed an order for a g0704 and a
G0602, but they're both backordered. I figure I'll snag the plans from you so
I can keep the wheel reinvention to a minimum. Intending to go with roton screws and oversized balls. I have a Bridgeport clone and an old
Clausing 12x40 lathe so the conversion should be a piece of cake.
Ian
will the precut stock kit come with the phase 2 plans as well? the link goes to the phase 1 and 2 plans together just didnt spell it out in the stock kit link...
http://www.g0704.blogspot.com/
