Page 243 of 395 FirstFirst ... 143193233240241242243244245246253293343 ... LastLast
Results 2,905 to 2,916 of 4733
Like Tree2Likes
Thread: Hoss's G0704
  1. #2905
    Gold Member hoss2006's Avatar
    Apr 2006
    Hey Leo,
    80 psi is only giving you about 550 lbs of force.
    To be able to get more you can tap out the hole for the quill lock (I used 5/16-18)
    and replace it with a bolt or socket screw, I can get it much tighter now.
    If still no joy you could drill a shallow hole in the quill where the lock screw hits it
    so it also acts to pin it.
    The tip of the lock screw turned down below the minor diameter would prevent thread damage.
    There is a pin on the right side of the head to remove so the worm will pull out the front.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #2906
    Apr 2007
    I feel really silly now. I saw what I thought was a PEM threaded insert. Didn't realize it was just a pin.
    Thanks for the tip on the lock. Will do what you suggested.
    So with only 550lbs being able to release the tool holder, that would mean my holding force is too low!
    I used the A-7Q-9-32050 from SDP-SI which are rated at 340 lbs compressed. I just realized my mistake between series and parallel arrangement. I will try them in parallel.
    Do you know how much force the stock bearings can handle?
    Leo
  3. #2907
    Apr 2006
    Even the smaller upper tapered roller stock bearing has a static load of several thousand pounds.
    Crank as much psi as you can into that 3 inch air cylinder, 125pi would give you close to 900lbs
    which should give enough to open the collet with about 600-700 lbs pull for toolholding.
    Still a small amount but good for light duty work.
    If you come across a 4 inch cylinder sometime it would go with my floating power drawbar with no stress on the bearings.
    http://www.g0704.com/projects2.html#pdb2
    Plans are free for the asking at hoss@g0704.com.
    Hoss
  4. #2908
    Registered maker of things's Avatar
    Mar 2012
    Grizzly originally had May 18th for available date, upon placing my order they moved the date to April (Friday the) 13th. I have my DVD fom Hoss, now I need to make room in the shop. Can one of you guys measure from the back of the cabinet to the back of the table when it is all the way to the rear for me? Also how tall is the table top off the floor?
    -Jon
  • #2909
    Apr 2006
    Well hopefully friday the 13th will be good luck.
    there's about 4 inches from the table to the rear and about 38 inches from the floor to the top of the table.
    Hoss
  • #2910
    Mar 2012
    Thanks for the measurements Hoss. Looks like I should be able nestle it next to my Jet 9x20.
    Do I get a merit badge for finally reading all 243 pages of this thread, or do I have to read the original one too?
    -Jon
  • #2911
    Apr 2006
    Ahh, you have to read them both and there's a pop quiz afterwards.
    Hoss
  • #2912
    Mar 2012
    Would it be ill advised to put the x stepper on the left side of the machine like the optima conversion?
    -Jon
  • #2913
    Mar 2012
    Would it be ill advised to put the x stepper on the left side of the machine like the optima conversion? I am doing a phase 1 conversion.
    -Jon
  • #2914
    Apr 2006
    It's personal preference. There's no benefit for one or the other.
    Hoss
  • #2915
    Apr 2006
    Here's a sneak peek at what I was working on yesterday on the mill, a new ally bed for my prusa printer to hold
    a 10x10 pane of glass and an ally lower to give more y travel.
    Nothing mounted yet, just laying there for a photo op.
    Milled all the pieces from a 12x12 1/4" ally plate.
    Hoss
    Attached Thumbnails Attached Thumbnails Hoss's G0704-101_0105_800x600.jpg   Hoss's G0704-101_0110_800x600.jpg
  • #2916
    Oct 2009
    Hey Hoss,
    Will you be gearing up to sell kits at some point? You have me mighty interested.
  • Page 243 of 395 FirstFirst ... 143193233240241242243244245246253293343 ... LastLast
    LinkBacks (?)
    1. 04-24-2013, 01:36 PM
    2. 04-24-2013, 05:17 AM
    3. 04-09-2013, 02:32 PM
    4. g0704
      Refback This thread
      04-04-2013, 01:23 AM
    5. Projects
      Refback Post #0
      03-27-2013, 07:50 PM
    6. 03-21-2013, 06:05 AM
    7. 03-18-2013, 02:06 AM
    8. 04-26-2012, 10:49 AM
    9. 03-27-2012, 08:05 AM
    10. 02-17-2012, 12:55 AM
    11. 02-12-2012, 06:59 AM
    12. 01-21-2012, 03:34 PM
    13. 12-28-2011, 01:34 PM
    14. 12-17-2011, 11:27 PM
    15. 11-07-2011, 12:07 PM
    16. 11-05-2011, 11:39 PM
    17. 09-03-2011, 03:38 AM
    18. 06-20-2011, 07:03 PM
    19. 04-20-2011, 02:25 PM
    20. 02-26-2011, 12:16 PM
    21. 02-13-2011, 04:08 AM
    22. 01-02-2011, 01:36 PM
    1. Hoss's ZX45
      By hoss2006 in forum Benchtop Machines
      Last Post: 09-06-2012, 10:23 AM
    2. Hoss's G0704
      Last Post: 09-10-2010, 02:40 AM
    3. G0704 ordered!!
      By mwood3 in forum Benchtop Machines
      Last Post: 08-17-2010, 06:50 PM
    4. G0704 problem
      By pike3e in forum Benchtop Machines
      Last Post: 07-27-2010, 05:33 AM
