Okay, it wasn't the tailstock, you did the Saddle. I want to do both really.
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
Yea, Sorry I was going to post it and got side tracked
http://www.cnczone.com/forums/mini_l...ini_lathe.html
Duh, I was even subscribed and still missed it, Thanks.
Hoss
Gosh, you've... really got some nice toys here. - Roy Batty -- [URL]http://www.g0704.com[/URL]
Glad you asked that question Connor, I was looking for the same thing.
Pat
cnczone.com/forums/benchtop_machines/148568-yax2c-yet_another_x2_conversion.html
Yeah, I used Chrome on the spindle spanner wrench.
Needs a coating of clear like they say or it will dull up with use.
Hoss
http://www.youtube.com/watch?v=83D3b3uh2b0&feature=player_embedded]G0704 Hoss Spindle Spanner Wrench.wmv - YouTube
Do you think it would be possible to put on a linear encoder similar to a DRO and have Mach use that as the input? That way you would never have to worry about backlash.
All--
First post, be gentle.
I own a Jet JMD-18 and a mini lathe 7x10 and have been pondering how to change the Jet to CNC for the last couple of years. I found the CNC-zone and it was very helpful to an enthusiastic but amateur machinist. After looking at new dovetail mills and the fact that my Jet does manual milling of aluminum quite well with only a 5" quill, I finally came to the the conclusion that I should just keep it maunal (a handy thing for quick projects) and buy a *new* drill-mill to be CNC'd. Woo-hoo!
I was looking at buying the X3 and SuperX3... but then I saw Hoss's thread on the small but mighy G0704 thread as was hooked. I ordered the Hoss's DVD on Sunday and it arrived yesterday (Wed) ... plus today I finally completed reading all 2836+ messages. (whew). To be frank, not sure of the behavior of some folks diss'n the Hoss-man's efforts, excellent documention and accomplishments in this incredible thread, but if you aren't happy here... just start your own thread. ;^)
Hoss--
You have an amazing thread here and have done simply stunning things with the "little" mill that would have my big mill friends going "holy crap". Your bin of parts and tricks should have McGyver jotting down notes as to foil the villian in the episode. IMO, you've done an outstanding job helping us noobs and some experience folks as well and I would like to just say *THANK-YOU*. You make the Web a great place to explore.
Now that I have a direction, after hitting the surplus shops in the Portland area... I found a nice slide out 19" cabinet/tray and a trusty Dell 48V server power supply with 15Amp for $85. Yes, now I've started.
However, I've got question on the G0704 mill. After reading the quality issues with the motor and controller in the 'early days'... how are the new units? Better, Worse or Random? Just trying of figure out what i need to plan for in 2012.
Thanks,
Ron
Thanks Ron, guys like you are why I do this stuff and am happy to help.
A motor still pops every now and again but nothing like the troubles they had.
They at least should have a free replacement handy now for quick shipment if needed.
They still run out of stock on the mills but the backorder wait doesn't seem to be very long now.
Thing is they get some stock in at one of their 3 warehouses and if you can't wait, you could request
a mill from one that's not in your normal delivery area for a small extra shipping charge.
Good luck, Hoss
Hoss--
Thanks, good to hear the quality has improved and spare are on this side of the international date line. My goal is to be able to do simple things with the CNC... plus you provided me a great reason to buy another mill. You da man!
Keep up the great work... and continue providing the rest of us an example to aspire to be.
Thanks,
Ron
Hi, Hoss. I ran across this and thought you'd be interested. It's an optical comparator / edgefinder for mounting in a mill, made out of a cheap webcam. Apparently Mach software has a video window, and the camera can be used for edge or spot finding, as well as for measuring and reverse engineering a part. Don't believe I've ever seen it discussed here.
CNC-Joe's WorkShop: CNC Projects - Mill Web Camera Edge Finder:
Thanks, I actually made one back in 08.
Optical Tool Setter - CNC - The Hossmachine Forum
Didn't have much use for it once I setup auto probing though.
Automatic Tool Probe - CNC - The Hossmachine Forum
Hoss
Ha! I should have guessed you had already done it!
