| LinkBack | Thread Tools | Search this Thread | Display Modes |
#121
| still need a lathe to bore them and such. if you just want to gear swap, they can be found here. http://www.g0704.com/Projects.html Hoss
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
#122
I've seen this motor package below being talked about around the zone. $239 for the motor and $229 for the driver from keling. 3HP and 6000RPM with 3.5 N-M of TQ. Would that ever be a feasible upgrade in the future to come? http://www.kelinginc.net/CNCmillingcontroller.html |
#123
I guess you could do rigid tapping and spindle indexing with that setup? would be something to look at.
__________________ http://www.g0704.blogspot.com/ |
#124
| Ya there are a few threads on the zone already. Looks pretty sweet so far. Hoss has already proved how much power the G0704 stock motor has, more then i will probably ever use but that would be a pretty sweet upgrade for ease of tapping, more power, and other features. |
#125
The reason for this is the driver or load pulsates at 20KHz or more and many meters just don't deal with that well. It might be more accurate with a normal meter to read the PS input current and convert to amps for the stepper. Most PS are around 90% efficient. If you call the output 55V that would be 2 to 1. If the readings are near correct then 1.7A x 3 would mean you only need a 6A supply for the mill and a 7A would leave room for a forth axes. In the previous post some were saying to use over a 10A supply which is just not needed in any way. One thing to look at is the difference in switching or coil power supplies. Most switching PS are some what over rated and just don't like pulsating loads and may need to be over sized to be reliable. Many switching supplies make RF noise or just burn out for no good reason. A transformer will never just shout off or burn out under normal use. Short term over loading is just fine and failure in the first 10 years is almost unheard of. For that reason for $20.00 more you can have a coil PS and be set for life. Just don't buy a 16A transformer! |
#126
| Just ordered my CNC plans from Hoss, im patiently awaiting my email ![]() Got the whole week to myself as the wife and youngun are out of town, should be a good week of mill modding
#127
| Got the X axis motor mount done this Morning, sorry no pictures wife has the camera your not missing much anyways as im very rusty on turning handles manually. I think it would have come out better if I had a boring head setup, i was kinda at a loss for how to accurately cut the square hole. Im sure that is more or less for clearance anyways but i got it done.Hoss, one thing I guess im overlooking is how to locate the two holes that must be drilled and tapped in the end of the X axis table. can you point me in the right direction on this? otherwise awesome set of prints and good pics.
#128
| A boring head or a DRO would be real helpful. Keeping track of the expanding position plus backlash in the handles can be a chore. Rotary table would be another way to get round bores. Pre-drilling the corners and then dropping the center out as a slug could be easier too. Pretty simple to eyeball it that way. I'm curious on locating the mounting holes properly as well. Wish I had a whole week of alone time in the basement. A couple of hours each night feels like I'm creeping along on it forever. |
#129
. I think i will probly remake it or go on to a fancier design after i have cnc up and running.
#131
#132
| The x bracket is placed on the tables end plate centered on the hub and then mark the 2 hole locations. could use a small clamp tp hold the x bracket and drill the holes with a hand drill. this starter package is a good one. http://www.littlemachineshop.com/pro...gory=-74669629 others on my site under accessories. Hoss
| Tags |
| hoss g0704 |
| Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
| Hoss's ZX45 | hoss2006 | Benchtop Machines | 197 | 02-17-2011 06:30 PM |
| Hoss's G0704 | hoss2006 | Benchtop Machines | 926 | 09-10-2010 01:40 AM |
| G0704 ordered!! | mwood3 | Benchtop Machines | 48 | 08-17-2010 05:50 PM |
| G0704 problem | pike3e | Benchtop Machines | 6 | 07-27-2010 04:33 AM |
