Results 1 to 4 of 4
Thread: Are these oldhams too small?
    Jun 2004
    I came across some oldham couplers on the web advertised at $5 with a very lousy description. They were just called clamp oldham 1/4 X 5/16 .75 OD which I assumed meant a single hub with 1/4" bore diameter and 5/16 bore depth. At $5 a piece, I decided to order 4 of them along with some acetal discs. I wasn't sure that the .75 diameter would be strong enough but I looked at this product detail chart from McMaster thinking they might be similar:
    My thought process was the .75 diameter 1/4" bore oldhams at mcmaster had a peak torque of 93 in pounds which equates to 1488 ounce inches - way more than the 425 oz inch stepper I planned to use on the X and Y of my G0704. I will admit - this was a complete guess on my part and I may not even be comparing apples to apples.
    As it turns out, I received 4 full assemblies with 1/4 bore on one side and 5/16 on the other:
    Turns out these are Huco couplers. I looked up the part number off the coupler and came up with these 2 charts:
    So it looks like this is a 24 bore code and a size 19. According to the Huco chart, the torque capacity is 15 lb-in which is only like 240 ounce inches - a big difference from the mcmaster couplers (which I found out are Ruland as I ordered one for the Z).
    So will these things snap if I try to hook them up to some 425 oz-in steppers?
    Jun 2004
    Looking at Ruland's site, it appears McMaster lists the static break torque value and not the rated torque. The Ruland .75 diameter couplers are actually rated at 20 inch pounds.
    Jun 2004
    I'm just thinking (typing) out loud now - what if I were to make new 'discs' out of aluminum? I would lose the ability to break if it encountered too much torque but I would retain the quick-disconnect and ability to deal with some slight misalignment which is what I mostly like about these.
    Jun 2004
    Well, I decided to go with the 1" OD oldhams for the G0704 and I will attempt to use the .75" ones on the X2. If they snap, I will replace the discs with aluminum.
  1. Looking for small VC
    By Captdave in forum Want To Buy...Need help!
    Last Post: 10-08-2009, 04:26 PM
  2. Measuring small angles on small workpieces.
    By skiingman in forum Calibration and Measurement
    Last Post: 04-01-2009, 08:40 PM
  3. The bit is HOW small?
    By Rhodan in forum General Electronics Discussion
    Last Post: 12-05-2007, 11:59 PM
  4. Small Cut on SS
    By chakaloso in forum General Metalwork Discussion
    Last Post: 11-29-2007, 04:24 PM
  5. small CNC- plz help
    By Papcina in forum Open Source CNC Machine Designs
    Last Post: 03-08-2007, 04:18 PM
