Results 1 to 4 of 4
Thread: need replacement part
    Registered cary jacobson's Avatar
    Nov 2008
    hello-
    I ripped the threads out of my Y axis ball nut !! Anyone know a good place, good price, for a replacement ?? I do not have the specs., just it is for a max nc 15cl . Any help would be appreciated. Thanks, Cary
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    Inner our outer threads? And do you have a lathe? If so you can fix it with a Helicoil. You just chuck the screw up in the lathe, drill it out, tap it so a size bigger and place the Helicoil in to reduce it back down to the size it originally was. We own sprint cars and for is it is always a heart breaker when you strip threads out of a $40,000 aluminum engine block, this is how we fix it.
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    Registered pete from TN's Avatar
    Apr 2007
    Assuming.....
    I would take it apart and have a look closely at the ballnut looking for any part numbers or manufacturers markings, if there are none I would contact the manufacturer of the mill directly and see if they can either get you another one or give you a source to get one for yourself. I am also gonna assume you broke the threaded end off the ballnut itself which would not be easy to do but it has been done before and you are not talking about the mount getting the threads ripped out and the ballnut is still intact.. If you could give some more information it might be easier to help you as it may be repairable if the nut itself is not broken. Most ballnuts if not all are VERY hard material so retapping is just not gonna happen. If after all this fails and you cannot get one you could always get some other screw that has a similar ballnut and thread and have it machined to fit your machines movements.... Is it a square or round profile ballnut? Again some more info could help here... peace
    Pete
    Nov 2008
    hi- thanks for the responses. i ripped off the outter threads on the ball nut. where nut goes into the plate that slides. i have used helicoils myself. they are great, but not for this application, wish it was that simple. i know that i can buy this part from the machine vendor, but frankly, is way overpriced there. anyone know of a good aftermarket supplier for max nc parts ?? thanks, cary
  1. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 01:18 AM
  2. sheetmetal part? flatten a rolled part?
    By Rich05 in forum Solidworks
    Last Post: 08-12-2009, 11:22 PM
  3. Need Help!- Replacement part for Nardini Lathe
    By terryb in forum General Electronics Discussion
    Last Post: 04-22-2009, 10:49 PM
  4. Verify Cut part to Design part.
    By CaseyCAM in forum NCPlot G-Code editor / backplotter
    Last Post: 11-01-2008, 10:22 PM
  5. Newbie- Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum General Metalwork Discussion
    Last Post: 03-15-2008, 07:35 AM
