Results 1 to 4 of 4
Thread: What tool is need to round an edge
    Feb 2010
    I would like to round some edges on some straight parts so the are not so sharp and to make them look better. Is there a cutter I can buy that has a radius cut into it for this. I would be doing this on a manual mill so using CNC to do it is not an option yet
    Aug 2007
    Feb 2010
    Quote Originally Posted by hudd View Post
    IF you have an indexer and a ball nose end mill, then a corner radius cutter is a pretty easy make...But buying it would be considerably quicker.
    Jan 2010
    Depending on how big a radius you need, a good sharp file can do a good job. A .01 -.06inch radius can be put on fast. Do it in the "draw file" way and it will look good and works fast.
  1. X2 tool entry cuts edge of pocket
    By paulpounds in forum Mastercam
    Last Post: 03-24-2009, 03:01 PM
  2. 2D Contour on a round OD not very round :(
    By kojack in forum Mastercam
    Last Post: 08-10-2008, 08:07 PM
  3. Where to buy a half-round lathe tool bit?
    By ThomasAlva in forum Metal Working Tooling
    Last Post: 02-26-2008, 11:48 AM
  4. Replies: 3
    Last Post: 11-30-2007, 07:44 PM
  5. tool center or edge?
    By spock in forum BobCad-Cam
    Last Post: 02-05-2007, 01:45 AM
