Results 1 to 5 of 5
Thread: Hot stepper motor
    Jan 2010
    Hot stepper motor
    I have a X3 mill that I converted to CNC, using a kit from Keling, and the Y motor has always run hot. I have been doing some 3d cutting lately with long runtimes, and have really noticed ALOT of heat in the Y motor. The X motor runs around 100degrees, up to 120 max, but the Y has reached as high as 210.. It even stays hotter when not in use than the X by a good margin.
    What causes this? are there any fixes?
    Also, I posted this in general, but no responses yet. I need a Lathe chuck for a 6" rotary table, What size chuck should I buy? Will any of them fit/work well?
    www.steelplinkers.com
    Registered arizonavideo's Avatar
    May 2008
    I think 180 deg is max so it is a bit hot. I would lower the current setting a bit and see how it does. I have not heard of the coils going bad on a stepper yet so I would blame the driver for now.
    If the stepper runs hot and drops more steps then I would think one of the driver transistors is smoked or leaking current.
    You could flip the driver with the X and see if the heat follows the driver. If so it may have a problem or just the current setting is wrong. The switches don't always flip.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    What electronics are you using?
    If it is a gecko, i would suspect that the current is not reducing while the stepper is idle. That would increase the heat load even when the axis isn't moving.
    Fred
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Oct 2005
    Quote Originally Posted by binfordw View Post
    Hi
    what is the power supply, stepper driver you are using?
    what is the current you set?
    Max temp is 180F,210 is too high
    http://www.kelinginc.net/
    Jan 2010
    Thanks for the replies so far,
    This is the kit im using- http://www.kelinginc.net/Three34XCNCPackage.html
    1. Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
      By guy2b1 in forum DIY CNC Router Table Machines
      Last Post: 03-08-2011, 06:50 AM
    2. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
      By wf1318 in forum Stepper Motors and Drives
      Last Post: 07-25-2010, 03:19 AM
    3. use satellite dish actuator motor as a stepper motor
      By ozni in forum Stepper Motors and Drives
      Last Post: 06-18-2010, 08:55 PM
    4. Integrated stepper motor? with built-in stepper motor driver
      By uirobot in forum Product and Manufacturer Announcements
      Last Post: 06-07-2010, 04:59 AM
    5. Beltdrive-stepper motor-stepper motor driver
      By Georg in forum Stepper Motors and Drives
      Last Post: 10-16-2007, 05:56 PM
