Results 1 to 5 of 5
Thread: Plunge roughing??? Why
    May 2007
    Title says it all. What would be a good reason to use plunge roughing of a part?
    I just either haven't seen a need for it or maybe I don't understand why would it be used.
    Thoughts?
    Feb 2006
    You can use a drill bit to make deep pockets and save the fine detail cuts for your long endmill that will have to go slow due to deflection.
    Registered christinandavid's Avatar
    Aug 2009
    New Zealand
    The job I am doing at the moment has shown me the possible advantages of plunging. It is a large cast quick-hitch coupler for earth moving machinery. We have to machine the inside faces reaching down 250mm, which, when using an endmilling strategy causes the whole thing to flex and vibrate. Not good for the cutter or my ears. We have switched to a cutter designed for plunging, which is turning out to be quicker, less hassle and gives a more attractive, uniform finish.
    DP
    Registered LongRat's Avatar
    Apr 2005
    UK
    Most machines are more rigid vertically than any other direction, so with the right cutter and material it can be faster to rough out by plunging.
    May 2007
    Thanks for the info, this makes more sense. I just wasn't clear on the benefits of it.
    I can see where it would be useful on a deep pocket. I think I will try it when I do my next project.
    1. plunge roughing
      By conklin36 in forum EdgeCam
      Last Post: 05-15-2010, 09:09 AM
    2. Problem- Does the v23 demo have Plunge Roughing?
      By moldmker in forum BobCad-Cam
      Last Post: 02-18-2009, 03:01 PM
    3. plunge roughing techniques?
      By championp in forum Surfcam
      Last Post: 02-05-2007, 07:11 PM
    4. Plunge roughing?
      By RdHawg in forum Hypermill
      Last Post: 01-03-2007, 06:42 PM
    5. plunge roughing pockets
      By daw in forum General Metal Working Machines
      Last Post: 10-29-2003, 06:04 AM
