Results 1 to 3 of 3
Thread: High acceleration rates with ballscrews, X3 mill.
    Feb 2006
    I'm using servos on my cncfusion X3 mill with ballscrews. I have tons of power and can get crazy acceleration rates such that the mill acts like it hits a brick wall when it stops. The sheer inertia of the table stopping after a 120IPM rapid seems like it would damage the ball nuts and ballscrew. It's great for 3D and constant velocity machining, but I don't want to wear the machine too quickly. Is th is something I should worry about?
    -Jim
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    you can adjust your acceleration so that the motor will slow before coming to a dead hault.
    Jermie
    http://www.eartaker.net http://thehorticulture.net
    Feb 2006
    Thanks for the suggestion. I know I can turn down the acceleration, but then 3D machining will be slower and CV mode will be less accurate. I want to run as fast as possible without damaging the screws. I just don't know if I'm potentially damaging the screws.
    -Jim
    Edit, I like your icon, I'm building a collection of those right now out of stainless, just got permission to do so.
  1. Calculating acceleration rates
    By mcmmach in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 07-26-2010, 08:55 AM
  2. Replies: 6
    Last Post: 03-16-2008, 12:02 PM
  3. 8' high mill through a 7' high door?
    By iandm in forum Bridgeport and Hardinge Mills
    Last Post: 11-21-2006, 09:12 PM
  4. Mach 3 Mill feed rates
    By Ed_R in forum Mach Mill
    Last Post: 04-18-2006, 01:41 PM
  5. Mach2 for high feed rates?
    By InsaneEPP in forum Mach Software (ArtSoft software)
    Last Post: 10-26-2004, 07:17 PM
