Page 1 of 12 123411 ... LastLast
Results 1 to 12 of 138
Thread: I guess I will convert my G0704 too
    Jun 2004
    My impatience is getting the better of me so I started converting my G0704. I would have liked to have bought one of Ellik's kits but I just can't swing the cost so I am just doing it cheaply for now - As cheaply as I can anyway. I am going to re-use all of the existing thrust bearings, screws,etc. Later on I will replace all of the bearings and then maybe switch to ballscrews.
    So far, I have the X,Y, and Z stepper brackets made. Nothing real unique - because of my frugality, I am going with a front mounted stepper. I will just have to live with it and hopefully I don't drop a vise on it.
    The Z axis is nothing more than a stepper mount. I am leaving the column cap and its thrust bearing just as it is.
    Am I going to regret using the stock screws and bearings? I am just trying to spread out the cost a little - even once its CNC ready, you still need the electronics, the PC, and I will need to make some sort of enclosure and bench. I can scrounge up an old PC and I already have a couple spare 425 Oz Nema23s. I also already have licenses for Dolphin, Mach3, etc. I am guessing that not going to ballscrews and bearings would probably save me upwards of $300.
    When I converted the X2 I went right to ballscrews. I would imagine the stock screws would be quite a bit slower.
    Attached Thumbnails Attached Thumbnails I guess I will convert my G0704 too-x_axis_stepper_bracket.jpg   I guess I will convert my G0704 too-y_axis_stepper_bracket.jpg   I guess I will convert my G0704 too-z_axis_stepper_bracket.jpg
    Dec 2009
    I think Hoss is doing it very similar in his thread. I'd imagine that the screws are going to wear out the nuts pretty quickly if adjusted to reduce backlash. On mine (a PM-25 not a G0704) I can't get my backlash down to less than 0.006" (originally about 0.011") and that's with the nuts really squeezed down. They used too small a screw in my opinion because my hex keys can't reach on the short side and the long side is now twisting instead of getting the screw tighter and it's getting noticeably harder to crank as I tighten down.
    Anyway, I think it is a reasonable way to boot-strap and allow you to make more sophisticated parts for the better conversion later. Looks like no matter what, if this is the only mill you have that you may need some outside services to machine clearance under the table for the ball nuts.
    I plan to go that route too and I'm waiting to see what Hoss puts together as phase 1 of his conversion. The quill-friendly belt drive he is making is at the top of the list too, mine sounds like a rattling beer can in low gear if there is any interruption to the cut. I think the gears have way to much free play back there.
    Jun 2004
    Well, I have an X2 and an angle grinder - not sure if that will suffice. I plan on getting Hoss' belt drive plans here shortly as well.
    Tinkerer
    Nov 2009
    You wont regret the screws you have til you know better. Great work on the stepper mounts. Keep your eyes open on ebay for some ballscrews for in the future.
    Jun 2004
    OK, I decided to go with ballscrews. I ordered some from Chai - hopefully I will be able to mount them up OK. I am not too concerned about the X and Y screws - they are the RM1605 ones (screw is 16mm diameter and ballnut is 48mm diameter) but I opted for the RM2505 for the Z which is a screw of 25mm diameter and a ballnut of 62mm diameter - hopefully the ballnut will fit in the column OK. Won't know for a couple weeks I suppose - I am having him machine the ends for me as well.
    Aug 2007
    really interested inn how this turns out for you, I have a G0704 coming sometime in the next couple of months and I'm debating whether or not to go straight to ballscrews, may I ask what you ended up paying for them?
    also what specs did you give Chai? or does he have some on hand for the g0704?
    Thanks,
    -Doug
    Jun 2004
    Quote Originally Posted by DogWood View Post
    Thanks,
    -Doug
    The ballscrews were cheap. Less than what I paid for Rotons when I did my X2 and I only got 3 nuts and a single bolt then - cut it and machined it myself. This time I got 3 individual ones, 3 ballnuts, custom machining, and 4 bearing locknuts.
    I drew up the specs for him myself based off of the brackets I made. They will end up being off a little once I replace the factory bearings with AC bearings since the AC bearings are thinner than the factory ones but I will just make up for that with spacers - or possibly modify the brackets.
    Aug 2007
    I went with Nook XPRs when I did my X2, cut and machined them myself as well, still cleaning up the mess grinding them made.
    Jun 2004
    Yesterday, I received the VXB bearings I ordered for my conversion. 2 AC bearings for both the X and Y axis, a thrust bearing for the Z (to complement the existing one), and some new AC bearings for the spindle.
    Here are the AC bearings - I didn't have any luck finding shielded bearings for a decent price so I got unshielded. I am guessing that the side shown on the right is the side that faces the opposing bearing?
    I made the bearing pockets to fit the factory thrust bearings so the AC bearings already sat recessed a little since they are thinner than the thrust bearings that came with the mill. I have decided to make some protective covers so I recessed the bearing pockets a little more.
    They are recessed enough to fit these covers
    The covers sit directly on top of the AC bearings and is made so that it only presses against the inner raceway. Here is one installed in the X bracket.
    Here is a closeup of one of the covers installed on the bracket. They are just slightly smaller in diameter than the bearing pocket and sit flush with the outside of the bracket.
    Here is the X bracket installed with the bearing and cover
    Here is the Y bracket with the bearing and spacer installed
    Now I just have to wait for the ballscrews....
    Jun 2004
    I received my ballscrews from Chai yesterday. They look pretty decent. He did a good job on the end machining. I may have gone too big on the Z axis but I think everything will still fit. Looks like I will have to mill down the ballnut flange on the X axis a little - either that or create a groove in the table (that would be my last resort).
    Nov 2005
    are the flanges threaded on?
    FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
    Jun 2004
    No, they are integral to the ballnut.
  • Page 1 of 12 123411 ... LastLast
    1. Not sure where to post but guess what came today?
      By alexccmeister in forum Benchtop Machines
      Last Post: 11-15-2008, 08:36 PM
    2. little gcode problem i guess
      By ataxy in forum G-Code Programing
      Last Post: 10-28-2008, 02:34 PM
    3. Need Help!- GUESS: Home Limit or Both
      By Mr.Chips in forum General Electronics Discussion
      Last Post: 03-20-2008, 12:03 PM
    4. Guess this mystery sound.
      By ynneb in forum CNCzone Club House
      Last Post: 07-04-2005, 08:18 PM
    5. so i guess i need more volts to go past 300rpm
      By mike10 in forum Stepper Motors and Drives
      Last Post: 03-21-2005, 12:33 PM
