Results 1 to 3 of 3
Thread: -ZAY7045FG-1 w/ MT4 spindle
    Feb 2010
    Hello, I'm a newbie that good a pretty good deal on a zay7045. It came with metric spring collets and MT4 spring collet chuck. but these do not seem to be one of the standard ER sizes. so, not sure if I can buy ER collets to go into this collet chuck. I bought some metric end mills and these turned out to have imperial size shanks so I am back to needing imperial collets.
    The only thing I found is an MT4 spring collet chuck w/ ER40 spring collets. Is this my only option? I don't think this collet chuck will be correct for the current drawbar. I've done a search but not sure where to get a drawbar.
    I'm I going down the right path? I don't mind buying what I need but because one tool requires having another tool and so on I want to get it right the first time.
    Thanks,
    Andrew
    Attached Thumbnails Attached Thumbnails -ZAY7045FG-1 w/ MT4 spindle-2010-06-05_12.24.49.jpg
    Registered ninefinger's Avatar
    Sep 2006
    If you have a MT4 spindle then you can get MT4 end mill holders.
    A set for $115 - http://www.shars.com/products/view/1...et_4MT_381quot
    or search around their website - the have them in individual sizes too for ~ $13 to $24 each (be sure to get the ones for a draw bar - not the tang end)
    http://www.shars.com/product_categor...dapters?page=1
    I'm sure there are other vendors too..
    As you mentioned you could get an ER collet set too, but I like the individual holders as its easier to swap in a mounted tool than to loosen the collet nut, remove the tool, remove the nut and collet, the install the new collet, replace the nut.....you get the idea....mind you I have a NMTB30 spindle so the tool holders come out pretty easy.
    http://www.shars.com/products/view/2..._Collet_Holder for the collet chuck....
    As for a draw bar - make your own. The loads on the draw bar are pretty low. Use a piece of threaded rod (from your local hardware store) and put a pair of nuts on it at the end. Use a bit of locktite to help hold them in place and your good to go.
    Those collets that came with your machine are a "Chinese special". I've dug around a lot looking for the spec for those (or similar - came on an MT3 spindle machine) and its really obscure - a mix between an ER collet and ???. If I can rediscover what I found out about them I'll post it but I remember giving up finding them from an on line / non OEM source.
    Mike
    Feb 2010
    Thank you! great idea for the drawbar.
  1. ZAY7045fg/1
    By Etaniyani in forum Benchtop Machines
    Last Post: 02-26-2010, 11:25 AM
  2. ZAY7045FG/1 with Power Down Feed
    By rdenis in forum Benchtop Machines
    Last Post: 02-17-2010, 11:00 PM
  3. Lathemaster model: ZAY7045FG
    By wyobmf in forum Benchtop Machines
    Last Post: 01-25-2010, 07:38 AM
  4. Dro kit for Lathemaster ZAY7045FG
    By outlaw paintbal in forum Want To Buy...Need help!
    Last Post: 07-11-2009, 04:23 PM
  5. Lathemaster ZAY7045FG DRO question
    By Pbrozek in forum Benchtop Machines
    Last Post: 03-19-2009, 12:33 AM
