If you have a through hole you can use that to locate the part after you flip it over. I chucked up the drill bit that was used to make the hole and then
located the part by placing the through hole on the bit with out moving the vice or table. I don't know if that is an acceptable machine shop practice but it worked for me.
RWW
LinkBack URL
About LinkBacks
