Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Need ballscrew loose bearing supplier
    Oct 2005
    I made the mistake of buying a fellow poster's X2 project last winter. He had started doing a Hoss conversion but didn't have a modicum of ability. I had my first clue when I saw the sheet metal screws coming out the front of the control box over an inch long so you impaled yourself if you hit the E-stop button. No big, just change them for some machine screws. Then I found that the axis thrust bearings were "press fit" into the bores so they didn't spin at all. Stripped threads, and misaligned holes too. Finally finishing the Z axis and the "new" nut seemed really loose when I installed it. Christ, it's missing so many balls there could still be some more added to the body and the tube is empty. The sad part is this "Goofin" idiot made sure to take pictures hiding the flaws and never mentioned lost ball bearings or other flaws.
    I need to find which bearing house sells loose balls so I can pack the ball nut properly. Now that I see the Z nut is boned, I'm thinking it would be to my benefit to check the X and Y nuts that are already installed.
    Thanks in advance
    Dec 2003
    Did you check local bearing suppliers, most I have found supply individual ball bearings.
    Oct 2005
    I'll try that tomorrow. The local bearing house never has things in stock though and their prices....
    You are JUST THE MAN I wanted to yak at though. What are the gang plugs called that attach to AMC drive signal pins and where do you get them? I scored a server case that is going to house drives, power, and computer. It's a glorious size and everything will fit. X2 #1 is near done and the silly Yellow Screaming Mimi X2 #2 is next on the boards. I've found that putting things together takes up less room with less chance to break. Having it all in one case is better than several boxes.
    Dec 2003
    AMC connectors I get from DigiKey what are the pin numbers some are 16p some also have a smaller one for commutation if BLDC?
    Oct 2005
    X, Y, Z are 308T Brushed and 16 pins. A axis is brushless. Never made a cable so I'll need a tool too?
    Oct 2009
    canada
    Dec 2003
    If you look up the sheet on the AMC site it will tell you the Molex number, go to the Digikey site and you can order the plugs and pins.
    I got the crimper from somewhere like Jameco I believe, it was ridiculously cheap compared to Amp or Molex that are in the $150~$250 price range.
    The quality is on par with the high $$ ver also.
    Registered ZincBoy's Avatar
    Mar 2007
    I have replaced the balls in a ball nut on a salvaged ballscrew that had 3 balls total remaining. The balls were sourced from http://www.precisionballs.com/
    They have balls sized in less than tenths increments. Depending on your ball screw, you will need to find balls that _exactly_ match the existing ones (and preferably replace all of the balls with the new ones). Mine were 0.092623" in diameter.
    I measured the remaining balls with a tenths reading micrometer, but the more accuracy the better. I was under by a few tenths and the re-built screw has about 0.001" of backlash. It should have 0 as it was a pre-loaded P3 class ground screw when new. If you have a spring pre-load, then the size won't be quite as critical. Note that if you go oversize, your nut will lock on the screw and damage both the nut and screw.
    Buy a few extra as they tend to go for a wander
    Gold Member hoss2006's Avatar
    Apr 2006
    Roton nuts?
    I replaced mine with .1259 balls from ToolSupply, gave them about .001 backlash.
    http://stores.ebay.com/ToolSupply_Pl...34Q2ec0Q2em322
    http://www.hossmachine.info/forum/ya...Reduction.aspx
    Just ordered some .1263's to see if they'll fit at all and maybe get rid of all the backlash.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Registered knudsen's Avatar
    Feb 2010
    Quote Originally Posted by hoss2006 View Post
    Roton nuts?
    Ouch!
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
    Jan 2009
    Rotons look just like Thomson-Saginaw ball nuts....
    Any body know if they are both manufactured at the same facility (i.e. outsorced from China)
    I may be looking to replace the balls in my Thomson nuts. I mounted the Z screw last night and they felt like they had just a little play.
    Of course, despite my best efforts... "tink, tink, tink", this involved crawling around on the floor with a flash light, and then re-installing the nuts that some how got beyond the stop and spun out the end of the nut.
    Dec 2003
    Some of the ones I have reloaded have had two ball sizes, the difference is sometimes just a couple of thou, in this case they are loaded alternately.
  • Page 1 of 2 12 LastLast
    1. Newbie- Angular Contact Bearing Supplier
      By speedydumpster in forum Benchtop Machines
      Last Post: 03-18-2010, 03:09 AM
    2. help for mount bearing ballscrew
      By p_rabid in forum Linear and Rotary Motion
      Last Post: 05-16-2009, 04:11 AM
    3. skate bearing supplier (sourced!)
      By tankie in forum Australia, New Zealand Club house
      Last Post: 10-04-2007, 07:52 PM
    4. Ballscrew bearing question
      By pstockley in forum Mechanical Calculations/Engineering Design
      Last Post: 05-16-2006, 05:21 PM
    5. bearing mounts - ballscrew
      By cadman in forum Fadal
      Last Post: 05-25-2005, 06:11 PM
