Old 05-25-2005, 09:27 PM
CoffeeRich is on a distinguished road
Question Is there an all in one Z axis kit?
Just curious if anyone out there knows where I can find a z axis retro for my
HF mini mill. I am running the 200oz HobbyCNC kit and Im looking for some way to convert the rack to screw so I can get the entire thing CNCd. Im just looking to avoid fabricating the entire thing.
Rich
Old 05-26-2005, 12:22 AM
Moderator
Halfnutz is on a distinguished road
Not that I know of. I used Ron Steeles plans from the site advertised here. It works very well, but did take some time and a mill to make.Lokk around, you never know what youll find.
Halfnutz
Old 05-26-2005, 09:48 PM
I figured that
:frown: I guess I need to start ordering some parts and get this show on the road. Have any cheap sources for ball screws or acme with anti-backlash nuts?
Any help would be great. Thanks
Rich
Old 05-26-2005, 10:07 PM
Moderator
Cgheck out the conversion log that I did here: http://www.cnczone.com/forums/showthread.php?t=8497
Its called Harbor Freight Mill/Drill and its in the project log. The last half is about retrofitting a Mini Mill with ballscrews and Ron Steels plans. Theres enough pics and info, you could probably do it without the plans.
Halfnutz
Old 05-29-2005, 08:48 AM
Timing pulleys
Do you have a part number for those pulleys and belt? I have all of the other parts sourced but the pulleys and belt. Thanks
Rich
Old 06-12-2005, 09:01 PM
BeerFizz is on a distinguished road
http://www.kdntool.com/_sgt/m1m2s2_1.htm
Try this site. There is an ala carte section... He has a "z" component, he might sell separately.
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
No Encoder Counts On X Axis. Y=OK murphy625 CamSoft Products 5 03-08-2005 08:20 PM
2 axis to 3 axis conversion drembedded Bridgeport and Hardinge Mills 10 10-27-2004 11:32 AM
CNC Retrofit - Kit verses turn on and go MetDetect General Metal Working Machines 21 07-12-2004 10:06 PM
4th axis plans or kit seansear DIY-CNC Router Table Machines 5 04-01-2004 11:52 AM
