| hi i have a harbor freight micro mill model47158 dose any one know the type size of the lead screw and lifting screw? for the y and z axis i also have dails each hash mark=.001 inch is there a way to calculate the number of steps per unit to get 1 inch of travel in the x or y axis thanks for any help |
| You might want to check out this Yahoo Group... It specifically dicusses conversion of this mill to CNC. (I have one too and this group was very helpfull, everything is pretty much on topic.) http://groups.yahoo.com/group/hf47158toCNC
__________________ Nathan |
You can calculate exact no of steps for a specific distance by using the utility in MACH3. it will also depend whether you are running quarter step, eight step or other resolution. I have MicroMill with all three axis cnc, and they are not the same number for z as the x and y, You will also have to run them at different speeds, the z being at about 12 IPM and x and y at something in neighborhood of 18-24 IPM depending on your conversion setup. I am using an extended table, but the steps for the screws should be the same, if You do not have Mach3, you can still download it in demo mode and run the same part of the program to calculate steps. Email me direct if I can be of any further help/. Jthacher@fairfaxcounty.gov JT |
| HF Micro Mill ok? (newbie first post alert!) | Twmaster | Benchtop Machines | 17 | 01-07-2007 09:30 PM |
| New H/f Micro Mill Extended Y Base With Thk Linear Rails | heilcnc | General Metal Working Machines | 0 | 04-17-2005 06:05 PM |
| Micro Mark Mini mill converstion | CNCadmin | Vertical Mill, Lathe Project Log | 29 | 02-07-2005 09:27 PM |
| New to Mill and CNC - Can you mix a Mini and Micro Mill | Sherpa | Benchtop Machines | 2 | 09-09-2004 09:36 AM |
| Harbor freight micro mill? | Lizard2033 | Benchtop Machines | 1 | 06-25-2004 07:04 PM |
