Old 05-22-2005, 10:27 PM
drwc is on a distinguished road
Lightbulb timing belt reduction
I have converted a prazi 400 mill to cnc with flashcut stepper drive,using 4:1 timing belt speed reduction on steppers.This gives a max feed rate of 8 in per minute. I have stock acme threaded screws. I went with the 4:1 ratio to give greater positioning accuracy and greater torque at low speeds but clearly rapids are limited by slippage to 8 in per minute.What do you all think ,should i have gone with a lesser ratio? What would be the best compromise between speed and torque?
Old 05-22-2005, 10:48 PM
2muchstuff is on a distinguished road
You should not be having any slippage if you are using timing belts and pulleys. Is the slippage due to the belt jumping on the sprocket. Do you have enough belt tension. What size/ pitch belt are you using.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 05-22-2005, 11:29 PM
Splint is on a distinguished road
Are the pulleys securely fixed to the shafts?
Old 05-23-2005, 12:44 AM
Idle hands is on a distinguished road
Assuming there is no slippage, what stepping do you have? "Drivers are available in full-half step or micro-stepping versions"? What is the lead on your screws VS the max RPM of your output shaft? Hope any of this helps, good luck with it.
Old 05-23-2005, 01:32 PM
slippage
sorry, slippage is the wrong term, the drives lose steps and accuracy ,i presume due to torque fall off at higher stepper motor speeds.
Old 05-23-2005, 01:48 PM
ger21's Avatar
Try gearing 2:1 instead.
Old 05-23-2005, 03:31 PM
Gold Member
JFettig is on a distinguished road
You might even want to try 1:1 direct drive. The stepper motors highest torque comes from the lowest rpm and drops off quickly after that.
It also depends on stepper size and size of the machine.
Jon
Timing belt length calculator. dmgdesigns DIY-CNC Router Table Machines 2 01-05-2009 06:54 PM
timing belt question Aegeon DIY-CNC Router Table Machines 6 05-18-2005 09:50 AM
Belt reduction questions Please help!? Bird_E General Metal Working Machines 3 11-26-2004 07:55 AM
Any recommended Timing belt and pulley? starCNC General Metal Working Machines 10 07-31-2004 11:29 PM
Should you put grease on a timing belt? ynneb DIY-CNC Router Table Machines 5 04-22-2004 08:54 AM
