Results 1 to 12 of 12
Thread: RHINO ROBOTICS ST/7 CNC LATHE
    Feb 2010
    HI,
    I NEED TO FIND SOMEONE THAT IS RUNNING ONE OF THESE LATHES.
    ETHER A ST/7 OR ST/8 WITH THE FANUC 6T CONTROL (EMULATED).
    I KEEP TRYING TO FIRE IT UP BUT I KEEP COMMING UP WITH " OUT OF ENVIORMENT SPACE".
    IT HAS A 486DX MOTHERBOARD IN IT WITH A RHINO REV.1.1 ISA BOARD IN IT WITH ROM-DOS AND TWO FLASH DRIVES (PROGRAMS THAT RUN THE MACHINE).
    IF SOMEONE HAS ONE UP AND RUNNIG IT WOULD BE GREAT TO HEAR FROM YOU AND MAYBE CAN HELP ME GET THIS MACHINE BOOTED UP AND RUNNING???
    THANKS,
    MIKE
    Feb 2010
    i know nothing about this stuff.... but maybe try this
    http://support.microsoft.com/kb/230205
    http://www.computerhope.com/issues/ch000325.htm
    Feb 2010
    Thanks for the links but I have gone through all.
    I really need someone that is running one of these machines.
    They made 2 versions of controlers that used a 8088 processor (version 1), and the other used a 486DX (version 1.1 rhino board) version 2 control.
    The 8088 processor needed disks to get the machine started.
    The 486 DX has dos and the programs on the version 1.1 rhino board.
    I need to know if this version 2 needs a floppy to boot to the ROM-dos on the rhino board then the software on the flash drives also on the board..(that should have the shell command on it)..
    OR
    Am I setting up the BIOS wrong and the IRQ address are conflicting..
    OK this might sound like greek but I really need to find someone that is running one.
    AirAmp
    Registered Arich0908's Avatar
    Oct 2009
    BridgePort , CT
    Did you see there home page?
    This link looks good?
    http://www.rhinorobotics.com/st8-set.html
    There email address is there why dont you ask them.
    Feb 2010
    Thanks, yes I did contact them. They are doing inventory right now so not too much time to talk.
    I did talk to the tec. and he is a bit stumped for now.
    They will be getting back to me soon (I hope).
    Still need to talk to someone that has one running...
    Mike
    Feb 2010
    Runs great Now
    Just wanted to update the software problem I had with this lathe.
    I figured it out with the help of Datalite that made the Rom-Dos 6.22 and the flash chip inside the machine.
    I was able to get the software off the chip and run it from a ide chip hard drive I installed.
    I still start it with DOS but then it jumps into the lathe program and the machine runs great.
    I have had it running a few months now but thanks to the guys that helped me figure this one out..
    This is a great little servo lathe and is very accurate and runs flawless.
    It has a fanuc control and a 8 position tool turret with a tailstock.
    If anyone has a chance to get one of these it would be a great little machine for small parts.
    Thanks for the help guys..
    AirAmp
    Jan 2011
    I just bought a Rhino ST/7 I am trying to get up & running.
    I did not get any software for it.
    Can you help me get it running?
    Feb 2010
    I just sent you a PM..
    I think I can help you give me a call.
    AirAmp
    May 2009
    I just got a Rhino ST/6, also without the software. I am having a hard time tracking down a copy.
    The Rhino web-site says that PC requirements were really a only a DOS computer with a serial port. Will the ST/7 software work with ST/6?
    Feb 2010
    Rhino st/6
    I really do not know if that would work.
    The St/7 and 8 use a controler box that is a 486 computer but it has a board in it and all the breakout boxes and connects to the lathe that has the motion controlers in it with a 50 pin cable.
    Yours uses a RS232. I have never seen a st/6 or have any idea of what it has in it..
    Call Rhino Robotics and ask what software runs the ST/6 lathe is your best bet..
    The St/7/8 control is different and has different software all togeather since it sets up the control box.
    Sorry I couldn't help.
    Mike
    May 2009
    Thanks for the help anyway. It was a long shot but I thought that maybe the controller connected to the machine over RS-232 as well.
    I've given Rhino a call and they have provided a quote on the software, manuals and the workbooks. I am going to try to talk to one of their techs before I buy though. I want to see if the software is absolutely necessary. I would like to know if there is a way to just up-load the g-code directly to the machine. I already have software that will test the code. I just need a way to get it into the machine.
    May 2009
    Thought I would give an update on my status with my ST/6.
    I did buy the owners manual. It shows how to get connected to the ST/6 and how to upload a program to it.
    I have tried to get mine to do a simple program but there seems to be a problem with the controller. I have a message into Rhino for help.
    1. Rhino CNC Lathe ST/8
      By BBR in forum General Metal Working Machines
      Last Post: 10-02-2009, 04:29 AM
    2. Not sure where to post Rhino ST/8 CNC Lathe
      By bdphillips03 in forum General Metalwork Discussion
      Last Post: 01-31-2008, 09:10 AM
    3. Rhino ST/8 CNC Lathe
      By bdphillips03 in forum Mini Lathe
      Last Post: 01-29-2008, 03:58 PM
    4. interfacing rhino ST6 lathe
      By albert5 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-08-2008, 04:50 PM
    5. Rhino and an OL1 Lathe?
      By Jorge-D-Fuentes in forum General CAM Discussion
      Last Post: 03-08-2006, 06:18 PM
